enduro vet
16 -
Commercial link removed
Dusty , rent a van and shove it in http://www.dvca.co.uk/lots-for-auction.php on your doorstep ! ive sold a few things with them, and they have promo very well in catalogue before the sale and get a good classic bike crowd ..
Hi Guys any reason why a 2012 300 Racing Head with machined insert will NOT fit a 2013 racing ? Would rather just swap it complete rather than remove insert .. Cheers ,,,
I found a VERY clean 2012 GG 300 Racing for 3k a few weeks ago , I get on with it far better than the 2010 250 GG I had before , More Grip / Smoother, Regier suspension starting to let me hop !
If you have a new Michelin ( the best tyre ) .. Then as the guys say , do the job right ! When we fit a new Mich Trials tyre for a customer , We use bead sealer .. Clean the wheel up with Brake cleaner, gentle wire brush on spoke heads.. The we paint bead sealer on , before stretching on a New Tubeless rim tape ( Genuine Factory ones more expensive , but better quality)... Just to be sure , we than paint a layer of bead sealer around rim , before inflating it , often needing 80 + Psi to pop it out .. One of those seating mousse tubes is good for this .. Bead sealer looks messy, but actually peels of like Latex ..
Thanks CM, I guess that goes for any of the 125,s ... Wondering if someone has had a season and the general reliabilty of the latest Sherco 2012/ 2013 models , with view to buying a new 125 at end of the year ...
Any one OWN a late 2011/12/13 Sherco 125 , what's you thoughts on it reliability wise ? (For a Youth 13yr rider ) btw .. Cheers..
Sting you were correct !! Water pump seal in the wrong way round :blush: We replaced it a couple of weeks ago with Genuine GG 10mm, put new one on same way old one came off .. ( thanks Previous owner !). Fitted new one today , clutch feels much better, oil doesn't looking like dish washing liquid Lets hope clutch says nice and its not contaminated new plates.. At least we now know which way round they go , Thanks for your advice ..
Thanks guys, will over fill it with Putoline over night , drain off ( a bit ) and then run it a give it a load of slip.. Plan B, can still be to swap Master cylinder, but hopefully will not require.. Let you know how I get on , in case others have same problem..
2009 TXT Pro 125... Put a new Genuine GGUK ? Complete Clutch kit in DP , and few weeks ago, with master cylinder repair kit and bleed properly with Putoline mineral oil .. .. Ok for while , but noticed a bit of coolant loss, ( Putoline GG Recommend oil NOT Contaminated So replaced the water pump washer any way .. Clutch dragging and oil gone greeny / milky , so ordered full factory Water pump repair kit , with new shaft , tight fit 10 mm factory seal... Not loosing and coolant now , but Putoline oil still milky , despite about 4 changes whilst hot??? This is my boys bike ,and clutch not as smooth as a my 2010 250 pro .. What next change mater cylinder ? Its a got a large capacity S3 one on already , or PX it for a Sherco 125 !!!!!
Cheers Jon.. In UK South Coast , we ride in mainly DEEP ! mud , been running 2.5 rear recently as so slick ..
Hi Guys, Ive bought a tidy 2010 GG TXT 250 Pro. Noticed a Spacer on ignition cover, and turns out Bikes got an S3 Flywheel weight Its got 10 x 41, gearing , Noticed its got White fast throttle, so got a Black slow one coming ... Just starting out in Trials, but been riding Enduro /MX for years ( so just need to slow things down Lol)... The bike feels like a 4t , to me as thats what Iam really use to.. Ive read good things about Flywheel weights, slow Throttle , just checking this is a good set up for a Southern Shandy Drinking , Wobbler
Nice one rabie ... Now I know , ill keep my eye out for events in South / South West ... Thanks ..
Hi Are Yoofs ! allowed to compete in time Trails ? thinking a 13yr old on a 125 ( Trails bike ) ...Cheers..
Thanks Guys , ive done it on Enduro bikes in the past , so ill give it a go ... Cheers....
My 13 yr lad had his first trial last weekend ( Waterside Club ) fantastic club, great event .... We got an 09 Gas Gas 125 with Renthal Fatbars on... Fitted some 20mm risers and he reckons feels much nicer like his BMX !! When he is on full lock , he is really outstreched . Was thinking of triming bar width slighty ? On the basis that what may be fine for a 6" 2 bloke may not be right for a skinny 12-13yr old !! any ideas of bar set up please, trials dad,s
