digger 1
15 -
hi guys i have a bultaco 221 175 , the swinging arm spindel was ceased to the bushes and had to be cut out.The bushes were the rubber type, i have removed the rubber but there seems to be a thin metal bush which the rubber was atached to still inside the swining arm.Can anyone tell me if i have to remove these to fit new bushes and also what bushes to replace old ones
hi pschrauber your bike is mint and a credit to you with all the work you have puut into it hope mine turns out the same
hi guys thanks for that got this bike in bits, looked tonight and found no mountings for the air box only two home made hindges that look as if they fit inside the top of the air box
hi guys can any one tell me if there is a spacer between the front brake backing plate and the fork leg on a 221 175
bondy hi got back to the person i bought the bike off and heys found the mushroom so only need the ballbearing
hi bondy just got your email many thanks for that now i know the mushroom and ball bearing is missing. I will contact buultaco uk to see if they have them, will try to get some pics together when i start putting the bike back together
hi thanks for that the only thing is now where can i obtain one any ideas
Bought this bike in bits. Have noticed on the inside of the clutch pressure plate there is a needle roller bearing but can't find any part that fits the push rod which goes against the needle roller bearing. Can anybody help??
Just bought a 1979 Bultaco 175 sherpa. Found this site very useful so joined today. Restoring bike - would be good to hear from anyone who is restoring or has restored one.
