paxo
20 -
well unfortunately it's not looking good. I took off the magneto and if you hold the end of the crank there is a bit of play. The engine is now sat on the bench :-(. any recommendations about what else I should change while I have the casings apart...crank seals as a matter of course but advice very welcome. I have a Haynes manual which apparantly covers my model (159) but the images look to be older models, is there a better manual that I should be buying ? Oh and best place to buy all the bits ? Thanks in advance
thanks for the help and advice guys, I'm going to pull the casings off and have a good look this morning. I will let you know what I find.....fingers crossed
my sherpa 350 (159) runs ok but the motor feels and sounds a little bit 'gratey' to me, its been like that since i got it which isnt that long. my question is are the motors usually silent and normally smooth or are do they feel little bit gratey ? I sense a strip down coming on :-(
Thanks for the help guys and Sherpa325 that's it......many thanks I can crack on with it now. It's the old joke about finishing a rebuild and having bits left over eh, I always take loads of pictures while I'm taking the bikes apart as well but somehow i missed that one !
Embarrassingly I'm rebuilding my Sherpa 350t (159) after stripping it for a full overhaul and i cant for the life of me remember what this bracket is off ! Any ideas anyone ? Cheers
I've still got the original speedo drive on the rear spindle of my 76 sherpa 350t and wanting something that looks period so I'm not really interested in digital ones etc as good as they are. Can anyone recommend a reasonably priced speedo and cable from somewhere that has the period look ? I know you can buy a full kit from Spain etc but they cost hundreds and I don't really want to go silly spending that kind of money on it ! Thanks.
Anyone know if the rear wheel spindle on a 250t is the same size (ie diameter) as a 350t ? Cheers
Thanks for that....they are now on order :-)
Thanks for all the replies folks its appreciated. Regarding the KTM SX65 seals, I don't suppose you know the actual year of SX65 that's the same ? Cheers Paxo
I'm currently stripping the forks on my Sherpa 350 (159) and was expecting to find a circlip above the seals. There is no circlip and no groove to fit one ? Also there were 3 seals fitted rather than two......Is this normal on some models ? Any help appreciated. Cheers
that's great thanks for the help ! Paxo
My Bultaco Sherpa 350T (159) swingarm isn't in the best of condition. I've repaired it for the time being by welding but im just wondering if any of the later models will fit easy enough if I can find one. Anyone know if they will ? Cheers in advance Paxo
That's great thanks very much for the help :-) Paxo
The title says it all really. Will the forks from a 198 Bultaco Sherpa fit my old 159 ok ? Cheers in advance Paxo
