slik
    26
  • Yahoo
    stlikos@yahoo.gr
2,613 profile views
  1. Hello! Does someone know which is the torque Nm for the upper and lower triple clamp on a Gasgas txt 125gp 2019? Thanks, Stathis
  2. Thank you Peterh , nice bike , be nice till 200 hours !
  3. Nice job ! Could you post a picture of all the bike ?
  4. Also , ATF Dexron III , 400 cc . Drain the oil after you have hot the engine .
  5. Hi Peterh , after changing all the bearings , I did the same you have done and now its ok , everything is moving free . I did the same with the chain tensioner , to have more room there , so I can adjust correctly the rear wheel .
  6. Hello Peterh , did you solved the problem ? Mine has started the same . I believe that its the bearings , I will see them tomorrow . What did you do , changed the shock ?
  7. Its a raining day , so the picture is not very clear , but I hope it will help you . I am 95 Kg ( without breakfast ... ) so I needed to preload the spring to set the sag . Where exactly is your problem ?
  8. Hi Peterh I have a 2014 with elka suspension from the 2015 . There is no problem . Could you take a picture ?
  9. Hello , i dont really know about competinions license , i know about Aspergers syndrome ( speech and language pathologist and therapist ) . If you have a road licence , i cant think why cant you joint a competition . I think that it would be better for you to go to a trials school first or find some people to ride with them , before you go to a competition . Good luck , Stathis
  10. Thanks for all that information Peterh ! i also have a coffee coloured spark plug , but i am not fully contented . The previous owner made some changes to the carb . I have to find them and fix it ( pulled out the main get , says 105 and i messured it and its 140 ! , so i changed it with a 120 ) .) I wiil try buy the Boyesen Reeds and try the Chapion plug . I also like to clean the air filter after every ride . I love the bike too . My bigger problem is that i broke my toe and now i have to wait 3 weeks before i can ride again . So now its an opportunity to set the bike ! Sorry for my bad english .....
  11. Thank you gasgas249uk . Any other information for jetting is welcome . Why 70/1 ? The manual gives 100/1 .
  12. Hello from Greece . Just bought a jotagas 300 , 2014 . I would like to ask a standar jetting for the dellorto 26 carb ( main jet , pilot jet , needle .... ) , so i can adjust it . It is not absolutely clear in low raves . Thanks a lot , Stathis .
  13. slik
    Sherco Problem
    The backplate on the clutch is not bent or warped . Thats my realy problem , everything looks ok , and my engineer say that the problem is the quality of the gears . Thanks again for all the answers , its the only help i have .
  14. slik
    Sherco Problem
    Thank you copemech . The bearing is ok , no movement . I think , i have to open the cases .
