![](https://www.trialscentral.com/forums/uploads/set_resources_7/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
basecampkid
31 -
Hi Luke7129 standard 301 Fantic Carb settings are : Dellorto PHBH 26 BS Main Jet 102 Pilot Jet 45 Needle X5 2nd notch Slide 45 Air Screw 1 Turn out, dont forget, with Air screw its out to weaken mixture, in to richen, also standard plug is NGK B8ES, or Champion N3, hope this helps.
Hi Pete, my advice would be : 10T front sprocket, slow action throttle (Black Tube), Flywheel weight, definitely re pack tail pipe, middle box packing would make a difference, but is quite difficult to do, Carb settings which I find best assuming you have the std Dellorto Carb fitted are Main Jet 118, Pilot Jet 33,Slide 50,Needle D33, on 3rd notch from top, also mixture screw approx. 3 full turns out, also bear in mind that as its a mixture screw as apposed to an air screw, its out to richen , and in to weaken, any more advice you need just ask, will be happy to help.
Dust off your anorak and tell me about it...........
basecampkid replied to laird387's topic in Classic Trials
Picture of Birkett number 23 is 1980 Red Rose, section is at Back Cowm quarry, I was there observing with my Dad, could take you to exactly where that section is . -
Hi Tug, from memory, the best settings for that bike assuming its got the standard Dellorto carb fitted are : Main Jet 118 Pilot Jet 33 Slide 50 Needle D33 Needle Clip position 2nd from bottom Mixture screw approx 3 turns out also remember on this carb that as its got a mixture screw and not an air screw , its out to richen and in to weaken, will confirm these settings when I next go to my garage, anymore help needed, ask away.
Hi Post 4 is definitely Charles Coutard as Steve says.
Hi Post 81 Not sure of the rider but pretty sure 1981 Red Rose, sections in Shawforth Qharry, hope this helps.
Hi Post 14 is 1981 Red Rose Trial, sections Healey Stones.
Hi Post 69 is Pete Cartright on the Italjet I think 1981 Post 70/71 is Tony Calvert on the Gori 1981 Post 72 Mart Lampkin 1981.
Hi post 12 I think is 1981, sections Healey Stones.
Hi Post 77 as Steve says is Glen Scholey 80/81
Hi post 38 is Chris Griffin 200 Fantic 80/81
Hi Post 33 is John Lampkin 1986, not sure where.
Hi Post 71 1980 Red Rose, sections Back Cowm, don't know the rider post 74 is Yrjo Vesterinen I think 1982, not sure where.
Hi Post 8 is Rob Shepherd 1977 Peak Trial .
Hi Post 17 is Rob Shepherd 1980 Red Rose Trial, note the Prestige Finance bib he is wearing number 57, just checked program, sections at Back Cowm Quarry. Post 21 is definitely Hattori, I think 1980 Dave Rowland. Post 22 is Rob Shepherd 1980 Dave Rowland, rider number 29 in background is Paul Leech,rider number 39 is my mate Scott Rowland.
