blade7
29 -
cooked my head the outher day and need to replace the orings are they all the same size ? for 125 to 280 and year's as mine a 2001 so a non pro if some could post us a link to buy in the uk that would be great
After a set of montesa 315 fan blades as have two snapped off which other bikes share the same blade and not keen on spending £50 on a new fan set up
yer just wish i was a xxl size http://www.ebay.co.uk/itm/like/321081024755?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&chn=ps&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0-L&ff12=67&ff13=80&ff14=108&ff19=0 living in the southeast there not many place to try on many
After a new cheap trails helmet as old one taken a few knocks seen a few about but with not alot of ventilation can someone point me in the direction after a deal seen the spada trials helmet for a good price and look better than my current one
Right bought a flywheel puller i checked the coils for damage and resistance checked the stator loom all good re done all the earth connections as some of the wires where down few strands install a bridge rectifier like this took it for blast round the block and the rectifier what that big sliver thing ? and the extra resistor in there for ? think my fault must be with the transval 415 voltage regulator just order a new one as suggested but under load getting a steady 5v dc from digital meter to the fan
got one for £13.35 inc P+P just hope got the right one
thanks there out of stock but found some where else same price just wasn't sure if that was the right one
Can anyone confirm which flywheel puller fit a gas gas txt 280 2000 non pro fly wheel puller 27 x 1.0 rh ? and if so where a cheap place to get one many thanks
here the place your after http://www.poleswoodtrials.co.uk/ you need to be a member you can apply on line now i think get gate code pay you entry fee and ride all day no mx bike aloud or if your near Kings Langley can join http://www.berkotrials.com/ for nash mills and play over there if someone else is with you for £35 for the year
Not good news put new rectifier on started bike and it blew it to bits getting 14v ac before the rectifier any clue what else to check ?
just got a rectifier and coil this evening so at the weekend going to swap out and test at the weekend and will report back
thanks just a quick question the cdi and voltage regulator under the head stock which way they fit back in as took the bolt out both dropped down so fail the coil is it cdi on the left or right as you stand over the bike ?
Been using this one think the colour seem more like my loom http://www.trialspartsusa.com/diagrams/Kok2001.jpg
Its a txt 280 2000 non pro i checked all the wire's time to start swapping parts out now to find out what it is
Think I found the fault I am getting 20v dc @ the fan motor side could this cause the bike to cut out when hot and is this just the rectifier or stator if the rectifier where the best place to get a new one ?
