fatty
33 -
Looks good in White. I want one ! Fatty
Steve I use Gordon Farley for all my parts, Just email the part numbers from the manual and he has them in a day or so. I think he will even post them on as well. Have you broken yours ? Fatty
Hi Funnyfarm 85 I am also from the New Forest and yes a member of the Waterside Club. There is a couple of others on here as well. Waterside is a great club, lots of friendly help. There is a trial this weekend Sunday 15th, will you be there ? Fatty
I use a cheap camera case with belt loop and cable tie to the handle bars, Great for my keys, fags and lighter. Fatty
Hi Waterside jmcc have a meet there 13-9-15 joint with XHG Tigers. I'm sure another club normally use it a week or so before. Fatty
Thanks all for your replies. The problem I have is this, If I wash my bike in the back garden or on the drive down the side of my house our dog then walks dirt and water through the house. As you can imagine that does not go down well ! As I like to give the bike a really good clean each time I always seem to create quite a mess so I think I will try the local petrol station until they complain. Regards
Hi all. This may seem daft but I am about to have a gravel drive layed and don't really want be be washing my bike off on the drive as the gravel will end up full of mud and dirt. Don't want to do it in the back garden as that will end a muddy mess. Do any of you use the jetwash at a petrol station and if so do they ever complain? Any suggestions please Thanks fatty
Jrsunt Thank you for your reply, had a look today and found the end of the pipe as you say tucked up behind the radiator. Has some sort of valve in the end of it, guess it must be a one way valve. All cleaned up now ready for next weeks trials. Just hope the knee is better by then. Thanks Fatty
Hi all Hope some one can shed some light on this one. Whilst out practising yesterday I some how managed to go over the handlebars and the bike ended up upside down half way up a hill. The bike cut out but by the time I got back up to it and got it back on its wheels lots of oil had run out from what seemed to be under the fuel tank. Within a minute or so there seems to be lots of oil all down the frame, the fork legs and even the radiator was saturated. The bike started fine so I rode back gentle and checked the levels and topped the engine oil and continued to ride. I did find what looked like a breather from the rocker cover with a small valve on the end of a pipe, would this let that much oil out? Should I be looking for a problem or is this a normal thing to happen ? Regards Fatty
Pearson Not that I have ever done these but I am doing the back end on my 4RT this weekend and I have already removed the bearings on the Dog bone using a socket fairly easily I did notice in the book that when I come to do the bottom shock bearing it has a steel clip that holds it in. I believe its like a very fine circlip that if I am right has one each side of the bearing and you should get new clips with the new bearings Hope this helps Fatty
All, Thanks for the replies and advice. As I am way over the suggested 80 kgs I wi go for the stiffer spring and have a play with the settings. Won't make me ride any better I am sure ! Thanks Fatty
Hi All, I have a 2006 4RT and love the bike and have great fun on it. I was at a trial this weekend and some one took a few photos of me on the bike and when just riding off a section it looks like I have flattened the bike. I am 6ft 1" and weigh in at a hefty 105kgs, reading through some of the threads on here it would suggest the bike would be set up for around 75 - 85 kgs from the factory. Now I am a beginner so having the best suspension I am sure will not actually make me ride any better but looking at the attached photo it may make the bike look better under my load. I have not noticed it bottoming out but then I only really ride the beginners route so no major obstacles so far. I have not played with the suspension at all and I would guess in the 9 years of its life not a lot has been done to the suspension. Should I have it overhauled or go for stiffer springs ? Who in the south would be a good person to get this work done and help set it up again ? Thanks Fatty
Sammyd 173 Very observant. Counted the chain and it only had 98 links on, went and got a new chain and it now has 102 which I believe is the standard for a 4 rt . I have however now ordered some new sprockets to change the gearing from 10 / 41 and will now have 9 / 43 which seems to be the way a lot of people run these bikes, no doubt will need a longer chain now ! Any way despite the chain every thing else seems very good and it's great fun to ride Fatty
Well here goes I can now join in this section as I have just got myself a new toy 2006 4RT , not even tried it yet hopefully get out this weekend for a play Fatty
Well not had the bike out of the garage since collecting it but here is a photo I took when I collected it
