Hey Guys,
i just got a 198 sherpa from a friend, which i'm currently trying to "restore" -- well, - at least to get it running good and fast again.
I'm currently at the stage that i've got most of the engine parts disassembled, splitting the cases is the next step.
The problem i've got is that my piston looks like ****, - one piston ring is stuck (i'm sure i can free it up or make a new one), but the piston still doesn't look very good. It's got various scratches, - a damn-hard-to-move pin and all the other stuff everybody fears when pulling the top end. one way of using it again would be to coat it using carbon which does cost about 100 euro (2/3's of a new piston i guess)
Now i'm not sure about (re)using this piston again, or calling it junk and get one off a modern bike and make it fit. On one hand i've got a 250 cylinder barrel where the liner doesn't look too bad, but on the other hand i'd like to give this bike some more power as i'm not planning to use it primary as a tractor but to get to work through the city, while having the choice to take the forest or the road, so thinking of bumping it up to 370cc, - or whatever piston i can get and make fit somehow. I'm not sure about the 250 cylinder regarding whether i can machine a new liner with a bore of about 85+mm and make the ports work (is there enough meat?) and additionally i guess i'll have to change the size of the bolt radius for the barrel and head bolts, don't i?
Did anyone of you think off stuff like this, or am i just crazy? Does anyone know of a modern piston from another engine which fits almost and is easy to get? (at least regarding piston pin?) i don't want to have to machine my own conrod- but if i'll have to i have to, i guess.
I attached some pictures of the tools i had to build so far for disassembly. Currently i'm building the crankshaft removal tool, and think about fitting a light generator with a small rotor which has a weight of 700 gramms, to get rid of the 1700g femsa rotor.
I'd highly appreciate any thoughts and ideas about this stuff i mentioned, THANKS!
Best regards, ricardo
