stevem099
19 -
Ah brilliant info there thanks for that! Mine still has the dell carb so will have to see how she runs onces she's finished. Managed to fit the box and all the wiring now so in the final stages. And the will defiantly look into another kick start. That standard ones rather short lol Cheers steve
Had a read up on there website, looks good. sadly I can't make this Sunday as I have work but will definitely have to attend the next meeting how many members are there in folkstone club? Cheers Steve
Hi all thanks for all replies. Luckily my kill switch works. Rather important it seems from the above storeys! Tltel i was specking to someone who used to ride and he recommended your club as he used to be a member. Will look into joining once bikes sorted and will also try to get down to watch an event see what it's all about Many thanks Steve
Thanks for replies. I to am in south U.K. Ashford kent. I will keep my eyes peeled on ebay for some disk protectors does make sense to fit them Cheers Steve
Ah thank you, I had a look this morning and I can see where you mean.. That's pretty tight isn't it lol.. Then again I've noticed most things are on this bike I'm really looking forward to riding it what where the benefit of the mikuni over standard del carb? Cheers Steve
Hi all. I'm still rebuilding by bike at the minute but it's getting close to completion I have a few questions.. After I've had some practice time and run the bike in (an old beta techno) I'd like to have a go riding a proper trial. Is there any regulations etc to compete and if so where can I find these? My bike is rather tatty and I remember reading you must have things like balls on the end of your levers I've replaced mine but I'm missing plastics like fork covers, brake disk cover and want to know if these are needed in a trail? In hindsight If I'd spent a little more I could of got a lot cleaner example but have enjoyed rebuilding it and I suppose I know it's mechanically good now. If I enjoy the sport I plan on getting a newer bike next year and keeping this beta as a practice mess around bike Many thanks Steve
Hi all.. Im currently rebuilding an older 94-95 techno but long story short I've fitted a 98-99 engine and electrics. Currently I'm struggling to find a place to mount the later, much larger cdi unit. I was just wondering if anyone knew where it was fitted to the original bike? Many thanks steve
All fixed now got a new gasket from USA. Fitted it the correct way up (Doh) and no leaks! Just got to fit everything back on now and then give her a run thanks everyone who's helped.
Hi the one I need is the one underneath with the stepped back, Many thanks Steve
Ok brilliant I'll post one tonight when I finish work. this is my first trial bike, brought it as a wreck thinking it would be a cheap way to try the sport lol. In hindsight I wish I'd brought something newer as so many parts seem obsolete on the techno I've spent ages sourcing parts lol Many thanks steve
I've just compared them you are 100% correct they are indeed different! What a pain in the backside lol. I'm not buying another gasket set :-/ think if get away with a cut and shut of the two with a small bit of gasket sealant?
Ah this maybe why it leaked. I recently rebuilt engine with all new gaskets but the one I fitted was green with blue seals. I've ordered a new one online where it stated it would fit techno rev and evo 125-290cc I shall see how this measures up if not I'll try making my own. Thanks for your help. When normally fitting the ones with blue pipeing would you have that facing up towards the barrel? Cheers Steve
My apologies. I meant the base gasket. The head gaskets (o-rings) seem fine. Still learning all the terminology on these 2strokes haha Many thanks Steve
Hi all. Well I've finally finished rebuilding engine started after a few kicks much to my delight However it was leaking coolant from the base of the barrel.. Removed barrel and I believe I've found the issue just wanted to make sure. On head gasket should the silicon pattern and writeing face upwards? I believe I've fitted mine upside down lol Many thanks Steve
