315 Plug Fouling, Pwk 28 Carb Settings. Any Suggestion
my neighbour machined me this reducer out of a nylon billet its on the same lines as ones on sale to overcome the same problem fitting pwk's to fantic's all you do is use some liquid metal or upoxy glue to hold it on the carb
Carburettor Fuel Line
they should be separate or fold pipe in half and cut half way through it so you end up with a oval opening in the pipe which it can draw air through for both sides
Golden Tyres
after 4 events running at 3psi and walls not showing any signs of cracking, a small amount of wear after sundays trial, holds its pressure all week. either im lucky or other people have had tyres from bad batches, or fundamentally bad rim's/valves
Golden Tyres
im trying out a gecko at the mo and so far quite impressed with it, only done 3 events on it so far but the last was a real tyre tester (mud roots rocks and bloody wet) and it coped with it very well. I've allways run IRC's on my twinshocks and love em, my supplier said that gt had had some problems with some tyres but told him that mine was from a fresh batch so hopefully mine will be ok. will keep you posted on how it wears and so on
Show Me Your Twin Shocker!
my new toy
Monday music on Weds!
- North Devon Trials Clubs
https://sites.google...ertonmotorclub/ https://sites.google...rcycleclub/home- North Devon Trials Clubs
Torridge has a sw championship rd at beam quarry just outside of Torrington next sunday (26th), what you need to do is contact andy bramwell andy.bramwell@Hotmail.co.uk to get a subscription for the sw centre gazette (£20) per year each month it has all the entry forms in for that month or you will have to pay £1.50 per event for a form- Air Leak?
http://www.jimsandiford.co.uk/ will have seals or http://www.ebay.co.u...=item35d0b576fc if you want to try the epoxy, jb weld is good I did a Honda tlm crankcase with same problem as yours worked a treat- Honda Tlr 200 Tickover
http://www.honda-trials.com/forms/tlr200manual/TLR_Scan003.PDF- 315R Fading Out At Higher Revs
possibly blocked filter on side of carb or float height is to low and you are running the carb dry (by the time you've started it again its filled up) http://montesacota315.com/en/- New To Plymouth Devon
im looking forward to the knill, ripon tor/ruby rocks is a fab venue never been that hard in the last few years, hopefully will see ya there- Tlr Timing Chain Adjustment.
I take it you have had the engine running whilst you have tried to adjust it ??- new toy
- Nicely Done Tl125 In Britain - Anybody Seen It?
I saw the bike 2 weeks ago it now lives on the edge of Exmoor looks lovely in the flesh but has the wrong carb on it and doesn't run quite right at the moment,i will find out what tank unit it is when I see the bloke probably this weekend, as for the cg gearing the tl's 1st 2nd and 3rd gears are close together for trials 4th and 5th are road gears would have thought cg gears were to high and to far spaced I had a tl years ago and if my memory is right I ran 10t 52t sprockets and only needed 1st gear in real tight sections as it was so low geared - North Devon Trials Clubs
