bowesey4
  1. Thanks for this. What is the off the shelf solution you are referring to? I have very little experience with electrics so a plug and play solution would be ideal. Thanks
  2. Hi all sorry to repeat a subject that has probably been covered many times. Same issue as most really... Want to remove the throttle lag and smooth out power delivery on oset 12.5. I see there are a number of different solutions available (none from oset which is surprising) has anyone used a torque control module from pico amps? http://www.automotive.picoamps.de/en/download_en.htm http://www.automotive.picoamps.de/doc/TorqueModuleOSET.pdf Seems a little steep at 129 plus vat. If anyone has any experience or recommendations I would really appreciate it Cheers Michael
