haza3348
    5
  1. Fantastic info thank you! 30kg is a massive loss keep it up! Great news. Thanks again
  2. I'm not a suspension guy. But as said I am a bigger lad and needing to sort mine out. What is the +70mm/140mm replacement preloaded spacer can u link em by anychance
  3. Hi I'm in the same boat. Do you have details of the spring you run and the spacer you needed to make. Don't have access to a 3d printer but can knock somthing up on the lathe. Thanks
  4. Hi I have a 280 pro with a slipping clutch when accelerating, changed the gear oil to putoline light gear and that's not cured it. I'm thinking a new set of clutch plates. Is there anything else I should try or check before I get new plates? Thanks, harry
