Can anyone help with any knowledge of a strange old ‘bitsa’, trials motorbike I’m playing with? It’s registered as a DMW and the square section frame would suggest that it started out as one. The back end has been modified to support a Royal Enfield swinging arm and wheel. It’s thought the frame may have originally had a solid or plunger rear end. It’s got two rear sprockets bolted together, but I can’t see the point as it would be impossible to run a chain on the smaller due to it being against the larger. The front also has Royal Enfield forks and wheel. The engine’s a pre ’63 Tiger cub unit. The petrol tank’s probably also from an Enfield, but it’s been cut and welded and a separate oil tank formed at the back end. Most DMWs were 2-stroke if I recall correctly. There’s a natty little chain oiler using one of the rear frame sections. The registration is, I believe, Carlisle, although I was told it came from Newcastle. Someone’s obviously spent a tremendous amount of time and effort in putting it together and I’m wondering if it’s got an interesting history.
