mudplugger124
22 -
Can anyone let me know what the measurement was when new of the inside of the drum front and back. I want to see how badly worn mine are. I was thinking of ordering a set of oversized shoes.
My original carb is badly worn. Do I change it to a flat slide carb Kiehin or Oko or just replace with original one
Thanks for all the help. I found it, the edge of the O ring had broke off and got stuck in behind one of the paddles. I will give it a good try tomorrow.
The transmission oil is changed every couple of hours. It is frustrating it was working fine until last week.
I have a 2022 125cc GP. The last trial I rode at the weekend. The clutch got very heavy to pull in. And then it would get light again, the clutch still worked OK either way. What would cause this or is it normal.
Can anyone tell me the age of this bike
Yes the clutch is perfect now.
Put the S3 Digit lever on, cant beleave the difference that different levers make.
Thanks for the help that give me something to try.
I have just got a new 2020 125 factory for my son he has small hands, with the long orginal Braktec, the clutch was light but he had problem reaching the lever when out when I adjusted it in bit the bitting point was was near fully in. I changed it to a Apico short but this made the clutch very heavy but the bitting point was perfect. is there any other lever that would suit better or anything else to help.
I have a 2016 sherco 125. How do you know what fluid goes in the clutch master cylinder. Is it dot 4 or mineral fuild
I have got a 2012 300 pro. First and second is fine once I go into third and rev it the clutch slips. Will it need new plates. The oil that came out of it was like water and there was not a lot it. I use bel ray 75w in my son's sherco will this do ok and last how much oil goes in.
My water pump shaft is leaking water out when I took the impeller of they is a flat washer between it and the seal is this correct, should this washer be there or somewhere else on the shaft
Sherco 2015 ST125 standard Keihin jet sizes - help needed.
mudplugger124 replied to peterh's topic in Sherco
I have a 2016 125 st with a Keihin pwk 28. And it is standard with 48 pilot 125 main 3/4 out air screw -
Yes Kehin
