fantic 237
12 -
I have just had to walk away and leave it! I will take it apart tomorrow night and have a look, the crank is fine but the gearbox nips up when the case is tightend. Something is not right but I cant see it at the minute. Something so simple!!!!! Thank you for the advice with the website.
Hi I'm rebuilding a FM237 engine and I'm having trouble with getting enough of the output shaft through the left hand bearing to allow the washer and circlip to fit on. Would anybody have a diagram? I'm tempted to remove the gear cluster but can't see anything wrong. Could something be stopping the cluster moving over? I know this sounds self explanitory but wonder if someone has come across this before? Cheers Michael
Beta Rev 3 2002 Impeller West Of England Good Friday Trial
fantic 237 replied to fantic 237's topic in Beta
Hi Thank you very much! -
Hi, I know this is a long shot! but I have just got a Beta rev 3 2002 and wanted to ride the good friday trial,so was just checking the bike over and the Impeller is in three pieces! Would any body have one that is going to the meet or could I buy one? I live in kingsbridge and could collect I dont mind if its second hand, I have been waiting to ride and then this!
Thank you very much for the info, So it must be a 240 kickstart shaft I'm after unless I remove the flywheel weight. Does any body know the lenght of a 240 shaft? It may be easier to find a 240 shaft. My other options would be to re-engine it, Which unit would you fit if you had to choose?
It may not be as straight forward as I first thought, do you think the kick start shaft will be a 240 as well? I could remove the flywheel weight and use a 200 side casing but this will make the set up different.
Hi I need the 240 side cover beacause the flywheel has been fitted with an extra weight, this make the flywheel wider than normal. I would like to keep the bike as original as possible but I do realise it has already been modified I was told years ago by a gentleman called Mike Hann? I have had the bike since 1993
Hi! I wish I had got it sorted! I'm working on the TY250 at the minute. It's running but I need to find some rims. I'm going to see what it would cost to have the kick start shaft made!
Hi I'm restoring a ty250R and need a set of rims. The rims are DID at the minute are they the right rims or are they aftermarket? I need to replace them as they have corroded badly.
Does nobody want to say Hello?
Hi, I have just started to get the old girl going again after the kick start shaft snapped!!!!!! Very upset. Well I have it in bits and now the hard bit starts! How do I find a new kick start shaft or have one made? I would be interested in another engine if I could find one, its a forward kicking FM 237. I'm also after a 240 side casing as mine has a flywheel weight so is wider than a standard 156cc Look forward to sorting this out and getting back out riding her again. Hope you have a good Christmas! You can see what I have done with my holiday so far!!!!
Hi, I have just started to get the old girl going again after the kick start shaft snapped!!!!!! Very upset. Well I have it in bits and now the hard bit starts! How do I find a new kick start shaft or have one made? I would be interested in another engine if I could find one, its a forward kicking FM 237. Look forward to sorting this out and getting back out riding her again. Hope you have a good Christmas! You can see what I have done with my holiday so far!!!!
