turnypatriot
    17
1,757 profile views
  1. Cheers, got one orderd and got a pal on stand by with a vacuum pump, looks like I'll have to drop swing arm out again
  2. Hi removed stator and cleaned with wire wool, starting spot on hope this helps someone in future
  3. Hi need a rear master cylinder as tried to repair with kit but still not working,it's a 2002 sy250 anyone help with part nos or where I can get one cheers leigh
  4. turnypatriot
    Beta Rev 50
    Having problems starting my sons 50auto new plug fitted new fuel ,getting fuel to cylinder getting good spark just will not start any help appreciated
  5. Hi I've just got both of mine betas,the youngest a rev n go 50 7yo. The oldest a geared beta 80 11yo. My thinking is by Xmas oldest will be ready for a 125 and the youngest will be ready for the geared bike. I feel that a Rev n go is ok but after a few months they will be used to it so I wuold always pick a geared bike if possible.as long as they are big enough to get there feet down and hold it up. Kids learn quickly so I don't think clutch control will come to hard,just make sure they have a lanyard fitted for when they fall off
  6. My mate has neoprene fork protectors on his Gasgas they seem to do the job but there not easy to get off in case any grit got in behind them
  7. hi just repaired rear brake and noticed spacers on swingarm have been replaced with washers,seems to be ok but would like to have spacers back in,any ideas where i would get them from, there located between swing arm and frame when the bolt is threaded through to connect everything up
  8. hi it was just muck in the seal. really thin piece of plastic around fork leg then a few pumps it was sorted thanks for advice
  9. Checked fluid and found a lot of air in there,tried flicking the lever and topped up fluid. I now have a clutch
  10. Thanks for reply ,did read about film trick will try that before replacing seal
  11. hi noticed a leak on my left fork seal . How easy is it to change,or should i get a mech to do it
  12. hi been out for a few hours today, going to change oil this week as its really annoying me now .hope it cures it but any ideas gladly welcome . will check the arm tommorow
  13. hi just bought a scorpa 250, clutch does not seem to engage fully when lever is back to bar even when warmed up. has been suggested that gearbox oil could need changing.if so what would be recommended cheers leigh
  14. again thanks for all advice ,will try to rememrer the name of my bike in the future ha
  15. hi feel like a rite numpty its a scorpa not a sherco, but presume it would be the same solution to the clutch problem
