Back in the good old days we had one route to ride ( just before my time ) then we had 2 routes to enable the novices to still ride the same event as the more experianced riders then known as experts.
To become an expert you had to win a number of novice trials or come in the top 10% I think of the results of an open trial, anyway it was an achievement to go up to the top class and I think it took a number off years for most enthusiastic riders.
Lots has changed since then, mainly the bikes have got so good they almost ride themselves compared to original bikes from the 70's.
More importantly the skill set has changed and the riders have got older
Tomorrow we have a 'group' trial down here in Kent/East Sussex on one of our best pieces of natural terrain, so good we do actually have a one route trial here once a year and it is always a great success. BUT to keep everyone happy tomorrow's trial has effectively 6 routes ( 4 routes with a further 2 which are combinations as suggested above) and according to the online entry system there is only 34 advance entries for it and they are broken into 12 classes. Take those numbers in, lots of routes, lots of classes but few committed riders , what needs to be done to kick start this sport ?
You have to ask 'What does the ACU ( or any governing body) do for us ?'
These problems, rider classification and bike eligibility, have been going on for a long time and nothing appears to ever get resolved.
Section severity is at the heart of it, you may think you can ride up that snotty climb but you can't and 4 laps of failing it means next trial you will be looking for a more enjoyable ride. That results in riding down a route or getting a compeditive older bike to justify the move.
You will now find modified twinshocks being ridden on the easier route by experianced riders because they are cheaper than hand built 2018/pre 65's
The pre 65 scene in the South East is virtually dead, no (O.K. occasionally) big bikes and the compeditive championship of 10 years ago has gone.
I am not intending going to watch although we have got a couple of brave souls from down here in Kent having a go ( good luck Gravesend club) I would have just liked a bit of back story I am sure there has always been a build up in the past.
Perhaps I will get a look at a copy of TMX as I am not on any 'social media' type info sites
Go with the modern bike and just ride the easier routes, a twin shock will still typically be ridden on the easy route but significantly harder to ride as a novice.
If you are going to worry about the difference in unsprung weight between each end of a variable Spring rate Spring then I suggest you give up trials, as the first thing you add to your bike around here in the winter is a couple of Kilos of mud !
Yes I am aware that everything helps, in that case never eat a chip again.
I am not sure what you mean exactly, but if simply twisting the forks straight does not work my next step would be to slacken off all of the clamp points that's the 4 points on the yokes ( triple trees) the mudguard mounting and the wheel spindle then give it all a general shake and pull around, obviously I mean slight slacken and not loose or the forks will slide straight up through the yokes !
Then straighten the assembly and tighten, hopefully this will have it sorted of not then you may have a bent leg which would surprise me given the video evidence, hardly a big off !
I have just googled your style of oil pump and it is similar ( the same ) as used on an Ariel, the larger of the two pistons is the return pump. It is larger to ensure it is able to pump more out than is being put in, under the square headed screw is a spring and ball one way valve, I suggest a bit of muck has stopped this valve from seating properly and the return pump is then not doing its job.
How old is the pump ? It could of course just be worn out as it is a simple close fitting plain piston in a smooth ( ! ) bore, I suggest you remove the pump and inspect. The ball and spring behind the pump is really a back-up you have got to get the pump right first.
If you drained 300ml from the crankcase that's your problem, I am not familiar with the cub engine but somehow you have 'wet sumped' so that's either the pump not returning the oil at a high enough rate ( if at all ) or the oil system is simply draining itself into your sump due to lack of non return valves ??
I would suggest you get yourself a schematic of the oiling system and find out how it is meant to work.
Hopefully he's just twisted the forks in the yokes rather than bent them, hold the front wheel between your legs and pull on the handlebars to straighten, I seem to do it most rides !
My Ariel used to leak from the rocker covers after a days hard use, I cured it completely by adding large vent pipes to both rocker cover caps. These run vertically up under the tank and have a small gauze filter on the ends to stop muck being pulled in.
The engine was just not vented enough or it has a bit of blow-by, either way the venting cured the weeping problem.
Go with a proper trials tire, IRC or Michelin (no experiance of the new Dunlop)
You must remember it's the only thing touching the ground and giving you everything, grip, directional control, stability, power transfer, if you try a cheap imitation or knackered secondhand one you will not know if it's you or the bike that's failing the section !
Trials is still exceptional good value for money and the extra few quid on good tires cannot be underestimated.
Lastly, put a cheaper tire on and when you come to sell the bike the potential buyer will probably knock you for the cost of the tire anyway as they will more than likely want a proper one.
Modern riding techniques mean that ground clearance is not as important as it once was, you are just going to learn how to unweight the bike over obstacles or double blip etc. You may find your slightly lower ground clearance has advantages in the stability department.
At one time tight turning radius was all important, then moving the back round became possible so steering round was no longer the only way to position your bike.
I bet my Ariel turns tighter than your modern bike, there again I can't for the life of me move the back round ! ,it also has very good ground clearance as unweighting that hefferlump does not happen !
I am pleased you agree with me, I was more concerned with the miss-interpretation of the product shown and how it was being used to wrongly argue a point.
I agree that the system of clamping is not a good idea in this application.
The photograph of a bike rack on the floor is not a Dave Cooper rack and I think it's method of attachment is being miss interpreted.
There is an assembly which consists of a tow hitch and a horizontal square tube attached to a clamp which then goes onto the swan neck tow bar.
The two frames then slide into the horizontal tube and are held in place with pinch bolts, the bar that has been identified as going under the tow bar frame is in fact one of the bike supports, looks like the picture was taken at a garage sale.
Before everyone gets carried away with redesigning this product take a closer look
Two issues with the fibre glass tanks, firstly are they made with the correct resin ? Very difficult to prove as resin is resin, apart from the petrol resistant version is apparently very expensive and has to be purchased in quantities that only a mass producer would use hence the demise of your small producer ( Sammy Miller spares used to do HT5 tanks but were dropped a couple of years ago).
Secondly, accident damage, my last fibre glass tank all beautifully painted up only lasted a couple of trials, a simple drop in a jumble of rocks ended its life, it's alloy replacement has had numerous clouts with hard things and although looks a little secondhand is still able to carry on.
Build up to the Scott
in UK Trials Talk
Well anyone know the result ?
