dirtydalesman
36 -
Hi all. I'm currently rebuilding a 1955 DOT TDH I'm hoping to use for some pre 65 trials. It has the Earls type front forks. Not sure what to go with for shock absorbers. I got hold of some TLR 200 rears, and they are about the right length at 390mm, but one of them is dead, so they are not much use other than for keeping the front end together. Anyone got something laying around that might fit, or any suggestions? I don't want to spend too much on shocks initially, as it may take some experimenting to see exactly what is right for the bike.
Anyone got any 1986 Scottish 6 day photos?
dirtydalesman replied to dirtydalesman's topic in General Trials Talk
I don't suppose you could take a picture of the picture for me? I can't find that book available anywhere. -
That's lovely information, thanks for that! -
I could also see residue of a 77 on top. I did wonder if he did the following year too, but I can't see No 77 in the results. It could be a later event my dad did, but stick on numbers would be unusual. -
He was indeed. My dad bought the bike from him probably the following year. -
Just found out my Montesa Cota 330 finished 43rd on the 86 Scottish, got me wondering if there are any pictures out there of it in action?
I have some damage to my engine casing as pictured, that could do with repair. I know the outer covers are magnesium, but not sure about the engine casings themselves?
- 1 reply
- 1
Thanks chaps. I emailed Falcon and they were very helpful with correct oil volume and air pressure. I have pressurised as best I can with an airline regulated to the correct pressure, so I kept the trigger pulled as I released the inflator, hopefully not loosing too much air. The other side still has some pressure in, so I won't risk topping that up for now in case I make it worse! If they hold together for a trial on Wednesday, I'll get hold of a proper pump and set the pressure better.
Ah ok then, that explains it. There is no gas left in the non broken one either, so I guess I just run them as oil shocks for now. They seem to be working ok.
I thought that initially, but I thought usually the gas sits the other side of a floating piston, separate to the oil. That hole is direct to the oil chamber. I have filled it with oil and blanked the hole, seems to work as the other one. But then I'm a bit lost as to why there would then be an air valve?
Evening all. Went out for a play on the Montesa yesterday and one of the rear shocks cried enough. My dad got these with it in 1986. Presumably swapped to the ones on it because the valve parted company on one and the oil escaped. I haven't seen shocks like these before. Are the valves just for oil, or do you pressurise with air as well?
New Dalesman owner looking for some help
dirtydalesman replied to GraemeC's topic in General Trials Talk
Hi Graeme. Don't know if this helps you, but this is my 68 Dalesman with Puch forks. -
Hello, I'm rather late on the uptake here, but I have a couple of links that may be of assistance if your are still looking. For Puch parts I have used https://www.rbo.at/ in Austria. They seem to have pretty much everything. For manuals, this website is very useful http://www.puch-m125.org.uk/ Wheels, engine and front forks were all Puch M125 items. Though yours looks to have had uprated forks. I have an Amal carb on mine, as apposed to the standard Bing, but apart from that and the forks they look very similar. I've never seen 2 with the same exhaust either! Mine also has a Beamish front wheel, but I wouldn't call that an upgrade, the front brake is terrible!
Lovely, somewhat cleaner than mine!
I'm running 30:1. The oil is oil that was good back in the day. Now used up, so will mix with less with the new oil. However, that mix runs fine in the other bike, not oily at all, so it's irrelevant.
