Hi,
Just purchased a twin bearing upgrade set for my Sherpa, (No modification needed) the top bearing looks straight forward, however, before I start, can anyone give me a tip on the lower bearing assembly?
I take it that the old ball bearing racer has to come off to allow the new bearing to locate correctly, not entitly sure how to remove it without force.
I als take it that the lower bearing has to slide from the top to the bottome, however, it to tight to move over around 10mm of the shaft, does this need a tap or should it slide free to the bottom?
And another, in one of the forums, its said that there should be four wires coming off the flywheel, I only have three and the missing colour is that of a red wire. If anyone can help, it will be most appreciated,
Cheers,
Andy
