drca
    159
Posts posted by drca
  1. 10 hours ago, wakka said:
    I made up spacers for myTech forks works fine made from free machining alloy
    Made up wheel spacers  and the centre spacer + Tech axle as well got the right bearings its mint to ride
    so happy I did the change
    Thanks!  Here is what I understand:
    Wheel bearing
    The Tech Fork has a 20mm axle vs the 25mm on the Gas Gas. So I need to drop in some 6004 bearings in the Gas Gas wheel.
    Bearing spacer
    I need a new bearing spacer with an OD / ID that will match the 6004 bearings
    Wheel Axle
    I'll need a Tech Axle
    Fork clamps
    I'll need adapters to go 40mm to 39mm for the top and bottom clamp (4 of them - I think I saw these somewhere online...)
    Wheel spacer
    Not sure if I'll need any spacer to set the wheel centered in for fork and to align the brake disc with the brake caliper.
    Anything I am missing?
    Thanks!
    • Like 1
  2. My zooch is getting pretty beat up (bent sliders, several nicks in the sliders, starting to leak oil...).  So I can either keep fixing it (which range to fill in the nicks in the sliders with the usual mail polish trick and replace the oil seals to getting new sliders), but I found a tech fork for a reasonable price.  So I am wondering what would it take to put that tech on my GG.  Here is my list of questions:
    • Tech is 39mm, Zoock is 40mm, but I know there are adapters
    • Front brake (tech are usually using the braketech setup, mine has the older AJP (?)  Will that fit in?
    • Wheel axle - Will the stock GG axle fit?
    • Wheel spacers (that I can probably get made or buy)
    Am I missing anything?
    Thanks.
  3. 17 minutes ago, baldilocks said:
    You need a mallet to return the sump to its original shape and it's worth fitting new rubbers between the guard and the engine cases or you may quickly end up back where you started.
    Sump guard is quite easy, fit the front blots,  just a few turns. Then get the rubbers in place and if necessary use longer bolts to get the rear bolts started and then swap the correct ones in one at a time.
    Yeah... Got myself a new bash plate!  Then I'll beat the old one into submission as a spare ;-)
    I have all new rubbers too.
  4. 2 minutes ago, d2w said:
    If I may, I have a question for drca related to the situation; how do you ensure that your fixed frame will align with the engine? Do you simply make the weld with the engine in place? Or do you just "eyeball it", and then open up the mounting holes later if required (say with a file)?
    Thanks.
    Dale
    Well, it's a trials steel frame without a lower cradle so it really isn't the stiffest thing around especially at the front (you can bend the thing by hand if you are not careful!).  So my welder just makes sure that the crack in the mount is closed (tap it into place with a hammer) and weld it back together.
    Then the mounting sequence is: drop the engine in the frame, put the swingarm spindle in, put the lower rear engine bolt in, then the front engine mount bolt then the top bracket and slowly tightened everything in the same order a little bit at a time.  The challenge will be the bash plate.  If it's new (i.e. unmolested) it should drop pretty easy. If it's been bashed (flatened) , then mounting it can range from being a challenge to impossible.
    In the end my frame could be twisted a bit, but since trials is about riding on crappy terrain with under inflated tires...  it doesn't make much difference to me :-)
    Hope this helps.
  5. 41 minutes ago, peterb said:
    Yes you can. To get to the kickstart seal, tip the bike over to the left side and remove the clutch case, leaving the water pump hoses intact. Pry out the seal and replace.
    Hard to tell from the photo, but it looks like the oil is weeping out from the gearbox output shaft. Invariably, it is not the seal that is passing, but rather one or both of the 2 O rings that are placed behind the output shaft sleeve. The output shaft has a push fit sleeve over it, that the oil seal runs on. The sleeve can be twisted and pulled off with pliers. Usually, one O ring comes away with the sleeve, inside a recess, the other O ring (25 x 1mm from memory) is likely on the shaft. This is usually the source for leaks, but definitely change the oil seal anyway, they don't cost much. Bye, Peter B.
    Thanks!
    The kickstart side seems pretty straightforward.
    One the sprocket side, that looks a little more complicated... If I get it right, on the sprocket shaft there is (starting from the inside of the engine):
    • A 25 x 2.0 o-ring - ME25632025 (#25 on the 1st exploded view below)
    • a 25 x 1.5 o-ring - MT280212025 (#29 on the 1st exploded view below)
    • A bushing - MT280236046 (#24 on the 1st exploded view below).
    • An oil lip seal - ME25636024 (#37 on second exploded view)
    And to get to all of this, it means removing the left side engine case, which requires removing the ignition cover and the ignition...  Anything else?
    So now that I have the engine out of the frame, that might be a good time to do this service I guess!
  6. One of the rear engine mount on my 2013 Gas Gas TXT broke, so the frame is off to the welder to get fixed (bash plate flattened from too much bashing, which spreads out the frame, which in turn puts pressure no the engine mounts and I'd rather have the engine mount break than the engine cases crack!)  Now... I could bash on things less, but then I'd have to become a better rider first!
    So it's a good opportunity to finally do winter maintenance on the bike (which I keep pushing off because of the just incredible weather we've been having here in California).  I have a long list of things to do and it includes changing the seals around the kick starter shaft and gear shaft, both of which are seeping oil.
    Can I do that without taking the engine apart?
    Thanks.
  7. 1 minute ago, section swept said:
    Lot of work for extra 30cc’s! ?
    Yeah, altho work isn't as much the problem as the $'s.  I need to take the engine out because I have a cracked engine mount at the back (and it's cheaper than buying a new bike) so once the engine is out, changing the jug / piston isn't that big of a job (especially on a 2 stroke!).
  8. Hi:
    I sent the crank of my Fantic 300 to be rebuilt to my local shop and the guy said that he can't take it apart.  I am not sure of all the details but he says that it's not because there is something wrong with the crank but because he doesn't have a jig that has the right size / shape to accommodate that specific crank (the plate that goes between the two halves to push against).
    So... Anyone has has a Fantic crank rebuilt in the US and could recommend a shop that could do mine?
    Thanks.
  9. On 9/1/2017 at 0:54 AM, turbofurball said:
    There's marketing blurb about it and the TXTe maybe becoming a production bike in On the Pegs
    From what I got from the Gas Gas distributor in the USA, there will be two electric bikes coming out in 2018 - one without a clutch / gearbox (à la Electric Motion) in May (in the USA, maybe earlier in Europe) and one with the clutch and gearbox (similar to the one that Marc Colomer rode in Lourde last year) in June / July.
    http://www.gasgasmotos.es/en/news/780-the-new-gas-gas-electric-trial-bike-to-enjoy.html
    • Like 1
  10. Here is what the fork brace looks like compared to a new one...
    I measured the fork slider tubes for straightness by clamping down the lower fork, putting a micrometer dial on the slider and rotating the slider and it looks like the right side is bent 0.015" (0.4 mm)  at the top and the left side 0.005" (0.1 mm).  I just put everything together so that when the fork is compress the bend won't pinch the fork and we'll see how it goes.
    Trying to clear a couple of small logs (8" / 20cm diam) with a distance apart about the bike wheelbase.  1st gear, lift the front wheel a few inches to bump it on the first log, a little bit of clutch and throttle to try to land the front wheel on top of the next log...  Got squirely, landed short with the bars at a slight angle, handlebars yanked to the left, big "clang"... And it's not like I was trying to land a 2 meters drop, it was below walking speed, wheel about 50cm off the ground.  Oh well!
     Hope the fork tubes aren't bent!  Back to the garage to take everything apart and check it.
  12. 13 hours ago, lineaway said:
     For the carb swap you need a new intake boot (reed side), throttle cable and air filter boot spacer. If you can`t make it run with the Del Orto you have other problems.
    It ran before with the DellOrto and is back to running ok right now.  Every winter I do a refresh of my bike (cheaper than getting a new one) so I'll just put a new set of gaskets and a new float needle valve this winter when do the refresh and it'll be good (I am getting a new bike next summer so...).
    The Keihin was just that a few months ago I tried a Raga replica (same year as mine ( think) and it was much crisper at the bottom end than mine.  I am not sure if it was just better tuned, or the higher compression head or Keihin carb.  And since I have this spare PWK sitting on my bench that I got for really cheap for another project...
    DC
  13. 22 hours ago, lineaway said:
     By the way you never mentioned why you needed a new one.
    I've been having some carburation problems recently: rough running engine, inconsistent idle, stalling and hard to restart, running very rich on restart, running only on choke.... you name it...  It happened pretty suddently, so I cleaned the carb from top to bottom a couple of times (first time didn't help), checked the floats to make sure they didn't leak, checked for air leaks, put in new reeds, new air filter and it helped.
    Part of my winter bike maintenance I plan to rebuild the carb with a new set of gaskets and changing the gas needle (or float valve...) is probably not a bad idea.
    I was planning to do an upgrade to a Keihin PWK (I have a spare from another project)... so maybe that'll make it on the list for this winter.
    I'll email Chris at SplatShop tomorrow and ask him to set a needle aside for me and put it in my next shipment.
    DC
  14. 12 hours ago, oni nou said:
     * Tap the pin with a punch or something just slightly smaller in diameter than the pin to knock it through then grab the bit protruding at the opposite post with a pair of pliers and with a twisting motion pull it out....remove the float lever arm/plate and the valve will just slide or drop out depending which way up the carb is.
     * The needle size will be stamped on it [use a magnifying glass to read it easily]
      * You can get them from www.splatshop.co.uk or www.dellorto.co.uk Eurocarb
       * Rebuild kit that only includes o rings and gaskets and dust boot for the cable is available from the same places you get the valve as above also on Ebuy.
    https://youtu.be/WWVMXLSS1cA
    Thanks.
    I'll check it out again, but when I looked last time I had it apart, I could not see a hole where to push the pin out (looked like the end of the pin was pushed in a blind hole, that's why I posted.
    Anybody would know what the standard needle size it on the PHBL26BS for a 2013 GasGas TXT Pro 250?  I'd hate to have to take the carb apart just to get the needle size...
    DC
  15. I think I need to change the gas needle valve on my Dell'Orto.  I have a couple of questions:
    • What's the process to change it?  I tried to remove the pin that hold the lever that pushes on the gas needle to no avail...
    • What's the needle size? (apparently there are different sizes!)
    • Does anyone has a good source to get them?
    • How about a standard Dell'Orto rebuilt kit?
     Thanks.
  16. My fan has started to make a high pitch whine.  A gentle (!) tap on the side of the fan usually cured it for the rest of the ride, but now it keep coming back every time the fan goes on.  I am about to order a new fan, but I wanted to know if this was a frequent problem and if there was an easy fix.
    Thanks
  17. On 10/24/2017 at 5:36 PM, code54 said:
    Our local dealer is slow. -I can order from England and have it far quicker and often for less $.
    I think that dealers with low volume wait to bunch up orders before they place the order with the distributor to save on shipping...  Then it takes time for the distributor to pull the parts and ship, for the dealer to unpack, repack and ship...  I ordered parts on the 11th of October, and they dealer hasn't shipped them to me yet!!!
  18. On 9/26/2017 at 6:14 AM, huski said:
    Hi all,I've recently got a 2013 300 factory replica.Had to remove the tank,I've noticed the cdi just sits there with nothing to secure it there apart from it sitting on top of the radiator and being held down by the tank.Theres a loop welded to the frame,but if I cable tie to that it sits too high and I can't get the tank on .It looks like the cdi is too big to fit in the space? Any ideas please
    That's how my 2013 250 Pro is setup.  The wiring loom is pretty messy and packed up under there, but it's mile better than my Scorpa.
    I've been thinking about try to make a setup similar to the Sherco / Scorpa / Beta with the CDI hanging on the side of the cylinder, but since it's been working fine so far, I haven't had a need for it.
  19. 1 minute ago, lineaway said:
    Intake manifold and throttle cable. That carb you are getting will need going through.
    Thanks!  Where can I get the intake manifold (is it the one off the Raga?)?
    The carbs are actually close to new (Kawasaki factory supported mini top level racer moved to bigger bike and his dad was liquidating his stock of parts).
    Now... What's the magic jetting for the TXT 250 (main, pilot, needle and slide)?
    Denis
  20. I have a couple of bash plates that have been "flattened" from... well... bashing on things!  One is the stock Gas Gas the other one is a CSP brand.
    I would like to bend them back to their original shape (or as close as I can) with my hydraulic press.  I was wondering if anyone has any experience doing this  and if anyone had the smart of making a cardboard cutout of the original (unmolested) profile of the bash plate...
    Thank in advance for the help.
    DC
  21. Hi:
    I scored a pair Keihin PKW 28 from a motocross racer for cheap and I am going to use one to do a conversion on the Fantic 300 I am building up.  Since I'll have a spare one, I was wondering if it's worth doing the conversion on my 2013 250 TXT Pro too?  What are the pro's and con's and what other parts do I need?
    Thanks.
    DC
