mattl
  1. mattl replied to dixie's topic in Sherco
    Wayne, you're right just recieved the latest price list and it's $6,999 retail for the 3.2, the 4.5 enduro is lowered too.
  2. mattl replied to sherpa325's topic in Sherco
    That's a good idea but, if you look at Cabes' bike will find it's the closest to standard of any. No trick forks, not even the slider coating or magnesium triple clamps (Yes Raga's bike not just Montesa now has them), no stainless steel braided brake and clutch lines like everyone else, no special master cylinders or titanium bolts, or anything really special. Yes, all the top riders use the Keihen carb, and sure probably special porting and maybe even larger capacity cylinder (300) like Diego Garrido was trying last year, but his bike is not that different to production, weight especially, since no mag cases or swingarm. If there was a Cabes special it would probably be like the SSDT special of last year.
  3. mattl replied to dixie's topic in Sherco
    Wayne, are you sure? Our info we got on the latest prices a couple weeks ago was $7,699 retail for the 3.2F
  4. mattl posted a topic in USA Trials
    As a minder for the US team this year, just wanted to give info on what went on, it was a real dissapointment. The team was signed up to ride in the A class. The reason was the TDN has eased up in severity of the sections since 00, last year in Italy was just way easy in B, and with Geoff at his very best, same with Cody, Chris, and Ray, the thought was this was the time to do it. While walking the sections Friday, the first group of six were just insane, dangerous looking, jagged edged type blasts with virtually no run at that even Raga and Lampkin were complaining about, so the team dropped back to B, a very wise decision, as Vesty told us later, all the teams except Spain took a pounding. Dropping to B meant we were first out at 7:56 AM, and the whole day the guys were really riding great, everytime the clutch third ride was needed someone came through. On the second lap with over an hr. to finish, plenty of time we were pretty shocked to run into the Italians still on their first loop at section 9, this about six hrs. after our start. Then we were stuck behind Italy, Britian, and Spain by Section 11, the rest of the way. Trying to figure out which section to punch out on trying to get by was hard because the A teams were then spread out, the guys were forced to take fives to get back at section 15, the easiest of the trial. We also had the wrong info on the penalty points and grace period, no fault but our own, and this was a factor in Chris timing out by one minute. If we got in on time the score would have meant first in B . We kept trying to figure out if went quicker on loop one if could have made it but would have run into the A class sooner and had the same problem, unless we could have passed them when they stopped after the first loop, they just took so long on their first lap it was unusual. But, real proud of the way the guys rode, they did it as a team and rode their asses off, also proud of the womens team, they did the same, really rode as a team, just had a few too many mistakes mainly on the second lap can't do that at the level the rest of the top women are, but it was great to be there to help them both. Louise is really improving all the time, and she is someone that everyone was talking about. She is one of only a few top women that has the trick riding down to get her into position for the tight stuff.
  5. mattl replied to rsnider's topic in USA Trials
    Thanks Craig for putting up the results, and the photo of Pat, I talked to David Holther, results Editor of Cycle News last week about doing a story for him, but thanks!
  6. mattl replied to rsnider's topic in USA Trials
    Just want to thank whoever it was in the WOTA for putting the Motorama results on, I've been trying to post something since last night but keep buggering it up, Mo, Larry, and Curly would be proud, first timed out on the story then posted images without a heading, then the images were too large, in between rushing off to work, hope to get something out tonight, if not
  7. mattl replied to rsnider's topic in USA Trials
    I've got the top five in each class, can send in something in the next day or so.
  8. mattl replied to cota kid's topic in Sherco
    Retarding the timing on the 2.9s really is the most sensible thing for most people especially on the 04s, as the slow throttle tube didn't slow the bike down nearly as much as did the 03. Using the right tools, air impact wrench with compressor and a flywheel puller the job takes 15 minutes, just did it to the 2.9 demo bike yesterday and tried it out. The temps warmed up above freezing and it was very slippery, but the bike got better grip in worse conditions than it did when drier. This is all down to the power coming on so much softer right off, but not only that it can be ridden slower without stalling. I can't say enough how docile it makes that motor for the majority of riders, and also how easier it makes the bike start, no more of those wicked kick backs when starting. Just a tip, when removing shifter, take the 19mm socket used to remove flywheel nut and put it between the top of the chain tensioner and under the swingarm. This will leave enough slack in the chain to push it up while wiggling the shifter off (move rear wheel so the narrow portion of the chain link matches up to the top edge of the shifter where it clamps on the shaft, and it will come off easily). There's no need to undo the master link and remove the chain.
  9. mattl replied to cota kid's topic in Sherco
    Starting in 02 they advanced the timing for more snap for riders like Jarvis and experts but it can be a handfull for most riders. The bikes will also kickback like a mofo and it's really best for most to retard the timing. The 04 2.9 is very powerfull with the new ignition and exhaust, but retarding the timing and using the slow turn throttle turns the thing into an absolute tractor and the grip in wet conditions is improved so much more, the bike can be ridden much slower, stalls less, much smoother off idle but still has a lot of power in the mid and top range, but is just plain easier to ride. It also won't kick back anymore. If you don't want to use a strobe light just turn the stator plate counter clockwise, all the way at first. This will give a really good indication of the benefits, and then can go halfway to fine tune or whatever. Like triple 6 said just go to the Sherco or RYP site to see the Waynemeister's manual on how it's done.
  10. Fracman I think the win and especially the margin of victory in the Spanish opener is very impressive, it's in Spain of course but, the terrain was slippery when he likes the dry rocks, and it's surprising to me how much farther ahead of Cabestany and Frexia he was. What is even more impressive now with Raga since the indoors started, the photos show the kid has really bulked up, must be spending some serious time in the gym, this along with his recent results shows me he's going to be really after the outdoor title and this is going to be a great year to see if he can do it, maintain the consistency, and will the level go up with everyone else too?
  11. mattl replied to copemech's topic in Sherco
    Hey you guys will have to get in line! The pads are PXC and stands for Paxau Competicio and are only put on bikes Josep Paxau the designer and engineer breathes on, that's why they are on David's and Will Ibsen's works 2.9 and 1.25s, the're not for sale. I've been trying to get one for a couple years now, Daivd said he'd see what could do but the point of haivng one on there is to know that bike comes out of his shop Motos Paxau in Spain and is special.
  12. mattl replied to bigfoot's topic in Gas Gas
    It really does help being a dealer for the brands, and would say that you can take every single bike, put them in a line in front of me and can name every single thing that I love about each bike and every single thing that just drives me crazy about each bike. Then there's the importers of each brand . Joe, you may say that GasGas is the brand people love to hate, but I've noticed way back from that other site, since Lampkin switced from Beta Montesa is the brand that gets the most negative comments, just in an attack form anyway. Of course that has to do with some people seeming to always wanting to rub in the recent results, but was also the case when Frexia switched over and again when Laia Sainz just did! Guess that's because people assume it's because of Honda's money when it's really the montesa racing dept. that shells out every single penny they have, every single year, and knowing that those fine people work their asses off touches on a nerve in me when someone mentions Honda! But, if they join, those riders really know that they will be on a great team with a great bike. The Mont-HRC team is known as the best, and that's not meant to slight anyone. But, to keep this on the GG subject the 04s are just plain great! There are so many things that make them so, some mentioned, some not. There is a new reed cage with no spacer now between the cylinder and carb inlet, so guess this also has to do with the added smooth delivery this year? The Pro was always a great expert bike but now it's become a very easy to ride bike for everyone, and the qualtiy of the components from the tiny AJP master cylinders, steel braided lines, to the Iris chain and work of art anodised suspension linkage, to all those dished out bolts......could go on and on!
  13. Charlie agreed, just spent the last hour going through every one, and great job to everyone involved, and Andy, this site in just a very short period of time has been everything hoped for, you should be proud! Jarvis was using a Dellorto for the first time can remember!
  14. mattl replied to bigfoot's topic in Gas Gas
    good one, I guess Chevy or Dodge would have been a better example.
  15. Yeah thanks so much guys it was great, being able to stay online and check back to see what was going on!
