dont cover the holes in the rear fender, i preped mine for the scott, taped the holes up to prevent water and shi7e entering the box, had a 5 min warm up around the start field and the bike was choked up due to restricting the air. Use the mesh or leave em open. I've thought abut using the mesh on the filter lid mouth, but never tried it.
Very tricky mark, on the 04 rev3, the the top fork brace is part of the lower handlebar clamps. The tapered bars arn't a problem, (i fitted a set of renthals to my SY) but they wern't cheap at nearly
Can anyone tell me the web address for the Dougie Lampkin trials challange game. Now its quiet at work, i need something to do! I know it was mentioned not long ago, but never had chance to try it.
When the bike is running lean, it usually makes the power more lumpy and harder to bring the power in smoothly on the bottom end, bad for slippery conditions because it makes the rear wheel want to break traction. When you have it slightly rich, its good for the slippery stuff because the power is more linear and not as snatchy. Although it may not rev completly out every time it is more favourable at this time of the year, (its like running with the timing slightly retarded). When it is set up perfect, the engine should feel strong throughout the rev range, without any peaks or troughs in the power.
The mixture screw makes massive changes, the weather has alot to do with how your bike runs. I agree with charlie, if you ride on a tick over it 3rd/4th gear then crack the throttle open the engine should not faulter, it should want to throw you over the back and keep on pulling like that until it is flat out.
Brilliant result for dougie, shame grimbo couldn't have made it a one, two. Well done to Shaun, a big achievement in just riding one of those trials. Its got to be a good basis for his future, and a great boost for his confidance.
Rekon it must be the Gas Gas, They seem to need the most work most often. The scorpa surprised me, although it is tricky to work on, you dont seem to get many problems. Probably resulting in less overall working time.
when Honda took over the montesa marque, part of deal was to always produce a trials bike, and thats what they have done. They have kept costs down, got it more or less right on the drawing board and its proved time and time again to be a winning formular.
Why do you need more power, does the bike not produce enough? Is flat out in third too soft for you? I have not come up against anything that a 250 will not go up. Alot of riders seem to be under the misconception that more power makes them a better rider. wrong. More power can mean more problems to deal with
An underpowered bike will bring the best out of your riding. If you can make a 125 go vertically up 6ft without a kicker then your going to get on a 250 and it will feel like a main road.
I think these are the part no's, its a bit of guess work but fairly sure they will be similar. I can get my 04 parts book tomorrow and give you the correct no's.
ESTIMATED PART NO's
REAR FENDER main stripe 87135nn3770
REAR FENDER side decals 87136nn3770
87137nn3770
FRAME DECALS 87131nn3770
FRONT FENDER 87133nn3770
FORK LEG DECALS not sure on this one
SWINING ARM not sure on this one
Will post you the correct no's sometime tomorrow. :beard:
Vent Holes In Seat
in Montesa
Dont tape the holes over as it does not allow sufficiant air into the air box, making it feel choked up. The best thing to use is some mesh.
