turbofurball
    1,324
Posts posted by turbofurball
  1. 2 hours ago, scifi said:
    Using Laminated A4 is not really so good in British weather, any nail holes let the water in and the ink-jet print smears very quickly.
    You can put them up without putting nails in them, as someone said above you can add a duct tape tab top & bottom and staple through that, OR cut a notch out of the card before laminating, and that gives you somewhere to pierce it without letting water in.
    Laser printed will be far more fade resistant than inkjet.
  2. Are you making your own?  I'd suggest easy to spot coloured card (eg. fluro yellow) with large easy-to-read letters on - keeping it simple :)
    nb. for people with dyslexia a sans-serif font is usually easier to read, Arial Heavy is a good choice for this sort of thing.
    • Like 1
    I got my TY175, now dubbed "Pinkie Pie", back in February but it took until last Friday 'till I got it back into one piece ... and even then only because I was entered into the Downland trial today!  I didn't manage to finish* but did have a lot of fun, and I love this bike :)
    So, phase 1 has been Majesty-ised frame, lengthenned swing arm, steeper yokes, fatbar handlebars, Rock Shocks (very plush!), SM and Wes exhaust (very loud!), and lots of little fixed bits from where the previous owner didn't use any grease on anything.  This has taken it from an unrideable turkey (zero back suspension action) to really pleasant to ride - once I got to grips with it it doesn't feel a million miles from my old TXTPro at my level of riding.
    Next up?  A kickstand that's the right length is top of the list, but there's loads still to sort!
    * 33 stages over 30 miles off road was too much, I've only been doing light practice recently and didn't realise how rusty I've got ... lesson learned
    • Like 5
  4. Bultaco backwards is Ocatlub.  Say's it all really, doesn't it.
    More seriously, the earlier left kicker ones didn't appear to be worth more than half of what a later one was when I was looking, regardless of condition (though compared to Monts they all look a bit pricey).  I'd love one as I have a bad right knee, but ended up with a White Wonder instead, by accident.  You could always put it up for what you'd like to get, and see if you get any nibbles, then adjust your expectations as needed.
  5. Thanks, that's also handy info :)  (I'll be honest, I hadn't really thought about checking the Haynes for this ... as it stands I've decided to keep the stock airbox for the moment, so hopefully it'll run ok with minimal tweaking to allow for the exhaust and I'll worry about the carb later.  I might even go crazy and try a flat slide carb!
  6. 3 hours ago, technowaldo said:
    Think they are meant to stay dry it looks like a chromed finish on the bearing surface
    That would be why the ones we replaced were almost solid with rust, then.  Replaced with self-lubricating ones which might last longer, but were a PITA to fit as they have tighter tolerance for the press fit (and new o-rings, with plenty of grease on them to try and keep the crap out).
  7. Yes, my other half replaced the bearings in her Sachs, the top hats are pressed into the bearing so you have to use a lot of force to remove them.  After trying different things I had the most success with putting the shock in a vice and using two big screwdrivers, one each side, to lever it out.  Maybe there's a special tool I don't know about though, lol
  8. Apart from an intermittent air leak (I suspect the outlet rubber as it looks very sorry for itself, new one goes on tonight), and the stuck float, it seems to run nicely.
    There's a severe lack of engine braking, but I'm guessing that's nothing to do with the carb!
  9. Thanks I'll have a look, all the kits on ebay appear to be in the US or China though so I'm going to drop OKO UK an email to see if I can get one without a wait or excessive postage charge :)
    I don't want to pull the float bowl without having a fresh gasket on hand, as I don't know the history of the carb and could end up with a worse problem!
  10. So, the Cota has a 28mm OKO carb on it (the original carb came in a bix of bits, and has a big chunk missing out of it), and I have a couple of questions ...
    Where can I find a rebuild kit for it?
    What's a good starting position for the idle screw?
    Where sould I route the tube that comes out of the float bowl?  I seems to get pretty full of fuel for some reason, so I'm guessing the float is stuck (?)
    I'd really appreciate help with this so I'm not chasing my tail unnecessarily :)
  11. That would be like the Electric Motion adult bike's "125 / 250 / 300" power modes, then.  Makes sense from an electronics point of view, sometimes you might want more power at low revs and less at high ones and there's no way for the bike to read your mind!
  12. Cool, in the past I've done a lot of skate boot repairs and sometimes bonded stuff would be great but then break up because it wasn't designed for the kind of forces that were being asked of it ... hopefully this works better though!
  13. 20 hours ago, dadof2 said:
    Why?
    Given the way they like to have the back box re-packed every year already, if not more often, I figure it would make that worse.  Both my and my other half's Gasgas' shed about a kilo when we sorted the exhausts.
    A little academic now, as I sold my GG today :)
