Yeah basically. And still the same with new clutch. has plenty of free play at the lever, but the plunger on the master cylinder hits the lever instead of the adjuster, as the adjuster is wound so far out to even have a bite any where near the bars. (Pic attached) The clutch finger height is adjusted by the clutch pack thickness and the thickness is bang on but the finger height is 2.9mm off. It's reading 14.6mm instead of 17.5mm I'm sure this is the problem but can't see how if one measurement is in the other can be out is there something silly I'm missing?
