trialmarc
25 -
Thanks for your responses guys! @oni-nou: you are correct that the clip is reflection and it is in the groove around fork slider. Seals are SKF and they are only 2 months old. So here I am hoping it is not bushings as you say. I have seen forks being cleaned with plastic strip, is it a good alternative while I procure the tool? Thank you!!
Hello Guys! Paioli 38mm forks on my 2000 Rev3 leaks when the bike is parked for 10-15mins. If you imagine the direction of travel as reference axis, then the point of leak is 180 degrees. If I wipe away the oil leak and compress the forks few times and check oil on the stanchion, there is no oil leak. However if I park the bike for say 10-15 mins then oil leak can be seen. Suspension shop says that the oil seal is tight and the oil is leaking because of compromised o-ring. Has anyone experienced this? Is the o-ring a generic type i can find here in the USA? or do I get the o-ring from UK trials shops? Appreciate your help!
Thank you Dan. You assessment was accurate. The coil itself is seems to work although I had to get the stator rewound from Steve, and also replace the CDI. Now the bike starts with a single kick!
Thanks for the response folks! In case I need to buy a coil here in USA, could you please give me some shops I can try? all I see from my web searches are UK stores or UK sellers on eBay. Thanks much!
Hello folks! My 2000 Beta Rev3 2T 250 has some electrical problem and there is no spark at the plug. Checking the ignition coil resistance - primary is 0.7ohm and secondary side is 10k ohm which includes 5k ohm plug cap resistor. Searches on the forum seems to indicate that the primary side should be 3ohm; as another data point, my buddy's Evo primary side reads 2.7ohm. So i am assuming the lowered resistance is reducing the voltage across the primary by 75% so that may be reason for no spark. Could someone help by confirming if 3ohm is the right value? Also, is ignition coil specific to 2T/4T or are they the same -- i am guessing they would be the same, but not sure. I would like to purchase the coil from USA if possible - who should I try? I have not dealt with Beta directly so not sure if they are speedy enough. Thanks much in advance!
AFAIK, there is just owners manual in english/pdf and parts list in italian that you can find easily via betausa.com. There is no factory service manual, so consequently the main thing missing is torque specs. I am finding working on the bike is simpler than a typical enduro bike, and I post questions here if I have doubts about anything for my '00 rev3.
RFX is one option https://www.ebay.com/itm/RFX-Flexi-Flexible-Pivot-Forged-Brake-Clutch-Levers-lever-Trials-BETA-REV-3-blue-/390741414998
sounds like an excellent idea! Fork servicing is new to me so this info will definitely be useful. Yes, Northern California. The bike looks new because it was mostly sitting in the garage of previous owners. You may be aware -- California regulators think it is better to let really old bikes in the park from early May to end of September to regulate emissions than allowing the latest models!! So, the only reason I ended up with bike this old was it allowed me to ride year round (I do not know any private property nor I am near a federal land where you can ride year round). more info: https://www.dmv.ca.gov/portal/dmv/?1dmy&urile=wcm:path:/dmv_content_en/dmv/vr/ohvredgreen http://ohv.parks.ca.gov/?page_id=21928
LOL; fair point - the carb is out of the bike and open, thought may be i should ask. Thanks!
Hello folks! The main jet is 145 and pilot is 27.5 now. Do I need to worry about the jet needle clip position? The needle has 5C23 stamped on it, and clip is currently at 2nd groove from top. Thank you!
@oni nou: Thanks for your inputs. Per your suggestion, I will change fork seals, and will start looking for a spare shock. One additional question: if I buy a fork seal driver, will it work across other models of trials bikes, or newer beta models?
Hello! Been thinking about servicing front forks and rear shock of 2000 rev3 2T 250, and previous owner had the bike sitting around for probably 4-5 years. I have attached the pictures. The suspension seem to be working ok, but I would like to service and replace needed items to ensure its reliability. Do you have recommendation on what to replace and what tools you suggest I buy? Considering lead times, I would rather have things ready before starting on this project. Thanks much in advance!
After changing the ignition coil bike ran fine for couple weeks and there is no spark again and bike does not run -- I was talking to one of the local dealers and I was asked to make sure there is no bad ground connection. I plan to verify the continuity of ignition coil primary as well as secondary ground terminal to chassis. What else should I be checking? I would appreciate your insights into this. Thanks much.
Yes, I have already replaced it with BR7ES and bike starts fine, and that should do till I get the pilot jet in next few days. Thanks for the help guys!
Thank you @klonheadd and @danwilliams. I have already ordered the 27.5 pilot! Initially it was 65:1 which i based it on the Beta manual. Per recommendation from fellow riders, I am currently at 80:1. Since I also do some single tracks and ride along fire roads to access those single tracks, I will stick to 80:1. Out of curiosity, how does one get to know the carb model? With dirt bikes, things were pretty simple - the manual would say the carb model I do miss the attention to details of Honda manuals. Currently I have to stick with 2002 or prior models so I can ride year round (green/red sticker BS from Socialist Republic of California) Ok will do.
