I bought the bike toook it out of garage next day and started it up, when I put into 1st gear it lurched forward and to be honest **** me up as not expexting it, so been apprehensive, hence only on the stand, did the clutch “ fix”
i addjusted the hand lever so that the bite was just slack 3mm
on the plates , at the back it’s fixed and front it’s the cover that fixes it, sure I put them back as was
I know this has been covered loads of time and I have been through the Beta forum
i have done the “fix” with removing the glue, I have used light emery on the flat plates,
the oil in gearbox is Silkoleane light gear oil 75w. Which is 10/40 I believe, this was in when
purchased
i have done the refitting and when I start up on stand, depress clutch and put in 1st or 2nd and the back wheel spins, if I put brake on then I can rev and engine doesn’t cut out so it’s slipping
if put it in 4th or 5th the rear wheel doesn’t spin
new clutch oil in reservoir and all bled, enough play at hand control end
Hi Everyone, just bought a 2002 Beta Rev3 200, in the process of tiding it up a bit, and more of a project to keep me brain ticking as retired from work.
anyone got and advice or tips, had the sticking clutch issue but thanks to this site sorted it
Clutch slipping on Beta rev3 2002 200
in Beta
Hi thanks for the reply
i freed all the glue around the clutch plates as per the link on this site.
when the cover is taken of the plates are behind the cover that is held in place by 6 bolts, washers and springs
after the cleaning up I did the above in reverse
its a lot better than it was
i will strip and have another look !
thanks
