Canario
79 -
Toni won the last five x-trials. There is some pressure, but I don't see an end of his winning series. Canario
In this long and stoney section, it would have maybe needed more than one minder or none. Difficult to estimate, but from what I have seen it was not the most difficult/dangerous part of the section. Would be interesting to hear the opinion of Toby and other riders.
Jaime won yesterday by only seven faults. Toni had 13. Toby Martyn had a bad crash today and is out of the race.
Watching Jaime Busto on his new GasGas in the last two races, I would estimate, that this year could be a difficult one for Toni. Canario
Thank you very much. 👍 This means, that the first 2 Kicks are without any throttle? Canario
Canario started following Gasgas , Starting technique for ‘19 Vertical Combat?? , Rear shock removal and 3 others
I need 12 to 15 Kicks to get the cold engine started. The throttle is on while kicking and I close throttle between Kicks. As soon as the bike is running, I am also warmed up. 😉 Any suggestions are very much appreciated. Canario
I want to exchange the stock spring of the rear shock against a stiffer one. After looking into the spare parts book and reviewing the assembly directly at the bike, the plan would be: - Loosen both screws DIN 912 M10x80 holding the dog bones - Remove the rear screw of them completely and swivel the dog bones in order to be able to loose and remove the screw DIN 7984 M10x40 that fixes the lower end of the rear shock - Remove the upper screw and the rear shock Does this make sense or do other parts need to be disassembled first in the area of the lower end of the rear shock? Thanks, Canario.
Hi Erik, do you remember the number of the DL12? If we talk about the same bike, then it has a new owner now. ? Regards Canario
I have a 2019 Vertigo. After installing the GET-System what would I see regarding the operating hours? - The hours since installation of the GET-System - The total hours of operation of the engine Thanks Canario
I currently have a similar issue with my GasGas TXT. Yesterday I found the reason: The woodruff key sheared off and the flywheel turned on the crank shaft... Canario
Former GasGas Enduros are now labeled Rieju.
Yeah, especially looking from the right side.
These are exactly my thoughts about the new R2. I wanted to buy one and waited with impatience, but this graphical design is definitively a "nogo".
Such a beautiful graphical design! I would immediately buy one, if they were still available.
