Gobig
13 -
I take this https://www.amazon.it/gp/aw/d/B06XFXQ5TC?psc=1andref=ppx_pop_mob_b_asin_image
Translation "Hello, the filter jistie I have already mounted, I was doing extraordinary maintenance since the previous owner did not, as a fool I removed the sensor, now I have to adjust it with kscan The pin was full of thread lock bl, fortunately I unlocked it, the cable arrives in the week and I take the test. I am from the province of Brescia, we are not far away"
Ciao, il sovrafiltro l'ho già montato, stavo facendo manutenzione straordinaria visto che il precedente proprietario era quello che era, da sciocco ho tolto il sensore, ora devo regolarlo con kscan Il perno era pieno di blocca filetti?, per fortuna l'ho sbloccato, in settimana arriva il cavo e faccio il test. Io sono della provincia di Brescia, non siamo lontani
I had taken it to clean the filter in fact now the carburation is fat, the spark plug is black
move the position of the sensor affects the carburetion?
hammer + flame+ imprecations= i'm winner. he had put fillets everywhere
thank you very much for all the help Papapitufo proceeded to send me the program and recommend the cable, I also solved the problem with the LED light. now I am cursing because the previous owner has glued the front wheel spindle?????
Grazie mille dell'aiuto, domattina controllo??
Hi Rich, the site tells me that I can not send you messages send me a message with your email if can you
thank you very much to everyone who will help me
I have an update, from the bike I get only a red and a black cable and are connected to the capacitor, I have to connect there the led light?
thanks MrTurle, this manual did not have it
Hello everyone, I'm Matteo from Italy, I have a Ossa tr 280 of 2012, the bike is fine but I have a couple of problems to solve unfortunately in Italy there is nothing and there are no active forums, I need help I would need the kscan program and the explanation on how to build the connection cable in Italy it costs around 550 $ and the program is not found. can someone help me? I should also connect the front LED headlight but I do not have the switch on the handlebars, what are the cables to connect? I will put a hidden switch I apologize if my english is not perfect thanks a lot to everyone
