Mcasp
44 -
Bit of a late reply but I have a '98 same question ?? Thanks
Hi Can you change the crank seals on a '98 315 without splitting the cases??? Thanks
Haha snatching I meant !!! Although if I like a snicker bar !!! Th x will try carb clean then coil ! Btw was ok for a while until warmed up????
Hi all, Been out today on my 315 it was snacking a bit but running ok ,then it just died restarted but soon as under load died again ....repeat !!! Any ideas ?thanks
Good call ,compressed fork and job done !!! Thanks
Also is it 5w oil, and how much per fork ?? thanks
Hi, I'm having problems releasing the retaining bolt on the bottom of my 315d's left hand fork (compression) it is just spinning ,is there a knack to holding the innards ?? Thanks Paul
Thanks Pete I'll investigate
Hi all, After fitting a new clutch\water pump gasket to cure a small leak ,I ran the bike,started fine ,revved ok after maybe 2/3 minutes stopped firing (but still running very lumpy)and water entered the gearbox!!! When I remove the water pump seals etc ok removed clutch cover gasket ok,but Mick start shaft loose!!!! What's happened any ideas ???? Gasgas 125 txt pro 2009 Thanks in advance Paul
Hi guys, What grade of fork oil do I need (txt 125 pro 2009) ,how do I make sure cartridge is full and how much oil do I need? Thanks
What about a rack with a trials bike on and a trailer with another ? Using an insignia estate 2ltr diesel????
Hi all, My son has a g/g 125 txt pro 2009 I'm wondering as I'm changing front fork seals ,is the rear shock serviceable?? As it's 11 years old now ?? Thanks
On the I'm gonna strip clutch and have a look .not sure which fluid not changed it since had bike!!
