r1chard06
23 -
Fan motor you mean
The person looking at it wanted to no if the generator should produce low volts on idle and higher wen Running as it is on mine are is it faulty
The person that looking at it builds choppers from ground up the problem I have is the fan isn’t working once wired up how it should be bypassed thermostat so not that changed a few electrical components it does run wen on a battery
Yes to which one
Need to find some info out as I am having it looked at
How can I test my fan wireing if I remove thermostat and join wires fan doesn’t spin if I attach battery spins fine
I’m starting to think it’s radiator as it bypassed thermostat and it’s running wen revs are up but shuts off wen you idle
And yes impelor spins wen liked over
It’s had new water pump shaft seals ect the fan works with battery and now as bypassed thermostat
Think it stops or slows alot
Someone help me out I’m stuck engine keeps boiling coolant after about 20 mins the thermostat has been bypassed chAnged water pump radiator and pipes new head gasket no crack in head so what the held going on also wording been modified to bypass thermostat
Anyone tell me if head gaskets were different than 1993 model I thought was delta but has coolant tank that only came out on 93 one
Also you wouldn’t have a wording diagram and info on fork seals change I thought my bike was a 93 as it has coolant tank
Water cooled I think it’s a delta as looked at pics looks like mine with gold head and gasgas logo
