Creepytheclutchmaster
    136
1,984 profile views
  1. Can anyone recommend a bearing puller with a link to buy. that will pull the lower triple clamp bearing off old txt triple clamps .iv looked at the sealy one and it's not a puller god knows what it's for lol..cheers.
  2. I have found a parts book online shirts gasgas uk. its crap! it doesn't open the page schematics.thats why the question was does anyone know of any other good working uk parts schematics.
  3. I Recently bought and basket case txt 250 year 2000 model for a rebuild project and went straight online to buy a full gasket set and low n behold hardly any about.a few of the usual shops having the odd base gasket in etc.also searching for a good parts shimatic and non of them seem to work.went on gasgas uk shirts website and that wasn't very good.anybody know of a realy good eu/uk old gasgas parts schematic sales website.not gasgas uk it's crap and doesn't open the schematic pictures parts numbers etc thanks.
  4. Hi all found a good running tr34 picked it up yesterday the engine runs and starts very well which is a bonus but the cluch started to become abit random after about 20mins light slow rideing in tight flat Woods sometimes engaging far out (lever wise) and other times nearer the bar which is whare I like it.when I first took it out I could also seem to find a false neutral if you keep pushing down past first. But it's seems to have stopped doing it now lol which is weard.any info would be much appreciated and does anyone know what the best gearbox oil is for these engines. I'm thinking putoline light gear but any ideas from other owners. Cheers.
  5. Take the radeator air box and skid plate off it makes things a lot easier, sometimes getting the skid plate back on can be a mission if it's been bent in the past . A hydrolic lift stand helps alot.
  6. Just buy the tool. If you use a slide hammer you could loosen or damage the magnets inside the flywheel or if your realy unlucky crack the bearing housing in the casings. If the flywheel has been on for years then a slide hammer may not get it off anyway.
  7. Best idea would be to look on a gas gas spare parts schimatic for your bike. it will be clearer to exactly whare and which way round it goes.
  8. There is a 2005 scorpa sy250 on ebay now for 1200, might be a better buy than the older gasser.
  9. If its a total shed about 500 quid, if its rideable but needs seals bushings chain sprockets wheel bearings 750- 1000 quid.if it's good to go with new tyre's absolutely everything works it would be worth between 1500-2000. Look for a 2002 - 2008 beta rev 3.had loads of them over the years loads of cheap spares online, thay are the best out the old bikes.
  10. Last option a broken or poorly fitting wood ruff key on the crank the fly wheel may still seem tight but once it starts the fly wheel shifts on the crank and creates bad timeing, some times clicks back in place to seem OK. I had this happen on a 1991 yz125 it took ages to work out the problem went down the it must be cdi stator rewind route, it would run one minute and the next become erratic.
  11. I found over the years of owning old knackered bikes its never intermitant cdi, regulator or coil thay usually either work or thay don't. Bad on off switches are the usual culprit or corroded earths. If it sparks well enough to see and hear your stators fine, its pretty hard to get old sherco stator timeing wrong on all the shercos iv had the stator will only fit in its original position with one timeing mark unless you bend and pull all the wires about and ovalise the bolt holes. Unless you have an aftermarket stator.
  12. Have you connected the carb breather pipes wrong if you connect the breather outlets on both sides it will not run right,take all breather pipes off apart front the overflow. Check your petrol cap breather isn't blocked. take the float bowl off there is a tiny choke inlet that runs in the cast section of some of the sherco carb float bowls it's tiny it runs to the brass looking thin pipe jet that stands up in the float bowl can't think of what it actually called make sure it hasent become filld with like a varnish sludge. You may also have put the stator back on slightly out of position but it's not that likely as thay usually only go in its original position. Blow compressed air up the fuel over flow pipe not much just a tiny quick blast.
  13. Iv put a 140cc pit bike engine in a bultaco sherpa 125 rolling chassis works OK, but the gear ratio's aren't the best even with changing sprokets it's abit of a scrambler realy, you will find the same problem with the upright air cooled engines as thay are all geard for the road realy and don't have the flywheel weight of the original engine design , Still a fun project though and still a usable bike, mines even got a hydrolic clutch, it's better than a rolling chassis sitting in the corner of the shed, And makes a change from the rev 3.
  14. Sherco 290 or beta rev3, shercos don't have the best adjustments on the forks but are slightly lighter than the rev 3
  15. Cracks in your air box, poorly fitted air filter or perished inlet manifold. doubt it's an electrical issue if choke fixes it until the next stream splash.
