chrisexall
    4
  1. I've renewed the wiring loom and it worked for a bit then went back to being faulty. The only other bad bit of wiring was the battery display lead, especially the earth connection. I've removed it and at the moment it's working! Could this be a coincidence or could a bad earth cause this malfunction?
  2. No tones emitted when the map button is pressed.
  3. Hi Konrad No Regen lever. Every time it's switched on it goes through the map reset process inc sound. It has new map button.
  4. My controller seems to be jammed on the reset function. I've renewed the switch which hasn't cured it. Any ideas what to do next?
