rvktm
    7
  1. fancy trying a weight think gg trs sherco vertigo use the same rotor . the sherco cover looks the same shape as the jtg thanks for any help
  2. thanks had a good look on g2 not the easiest parts site to navigate .like the later rear brake lever set up 100 e though . hoping vince at jtg uk can help with parts
  3. just got 014 280 NICE bike much more capable than my 014 st 300 .what parts cross over think the sprockets are gg pro. k start trs .new one on my bike apeco do them. also apeco do gear and rear brake levers for jtg .piston /rod gg pro? clutch plates? the trs air filter looks the same ? nice things about my jtg had the upgraded clutch cover not good some one retrofitted a remote type rear brake master cylinder it works but the pedal has no feel / solid .also the brake lever shaft is wobbly [can i get a new shaft are they expensive] if i have to i can recon it but its a bit involved the worst bits no side stand any one got one will a trs one fit. how much for a new one thanks for any help i like odd bikes iv got huserberg
  4. need a new set do i get sherco or i think apeco do them.the bike has sat for a year and the clutch was stuck three of the plates the friction material was peeling of .think the oil was atf thanks
  5. thanks cascao iv got a lathe and small mill and if i have to ill make one the hard part is the slots in the taper . beta use an olle on there x trainer that uses the adjuster but it looks like you have to buy the lower fork to get it
  6. the rebound adjuster on my 014 sherco olle shock is broken iv managed to get it apart and remove the broken part just need a new adjuster any help even a parts shock or a used ohlins thanks
