rick1962uk
27 -
Many Thanks that explanes why they are so cheap
as title im after a 125 so me (61) and my 12 year old grandson can both use it at trials im just a clubman he has just started to ride question is will this be a good bike power/grip and how reliable are they or should i save a bit more for a gasgas or beta many thanks rick
Many thanks got it sorted droped the carb inlet a bit used 5mm fuel pipe for trials bikes and it went rond realy well ONE WORD OF WARNING to anyone with black pipe the new E10 fuel had eaten it alive the inside has rotted away almost filling the fuel filter
hi im just refreshing the scorpa for a trial soon but noticed the fuel hose is rock hard and shrunk so going to replace but tank side has a 90 degree bend and looks tight to the tank has anyone used straight hose and got away with it many thanks rick
Trouble is i can do a track day in my car but cant go praticing i love trials but need a fix i know a few pratice tracks that are waiting for the ACU that i think is wrong low numbers pre booked and lets get out before we loose a lot of riders
021the first frame is almost ready
rick1962uk commented on jozef's gallery image in TC Members Events Photos
no 3 difrant sources
quick update soaked the gasket inwater for a bit got it to fit put the bolts in to hold it in place will let it dry out for day or so and see what hapens might glue it in place with a bit of sealant
hi im rebuilding a gasgas txt280 pro 2006 and all ok but the crankcase gasket is just to tight as it goes around the crankshaft i have tried 3 gaskets all the same any idears
Trials Lessons near oxfordshire
rick1962uk replied to rick1962uk's topic in Trials Training And Technique
that sound what im after many thanks all and dan -
hi returned to trials and love it but missing something just cant ride as i should si could do with a few hours lessons do anyone know if there is anyone that do lessons near oxfordshire in the next month or two many thanks rick
i use splat https://www.splatshop.co.uk/formula-rear-brake-calliper-seal-kit.html
there are a few pratice tracks for trials around you and weedon has a few good sections https://www.acu.org.uk/centres-clubs/centres/South-Midland/default.aspx
x11 or dunlop looks good but will change it forks are fully up top will go for tyre and bars forward and give it a try so i know whats doung what i do yus the clutch but it is a bit snappy will have a play with that many thanks for the pointers
Many thanks will try that i am using the clutch will move the bars and have a try
