niponn
12 -
I will try to let it run for more than 5 minutes, without the police coming , hoping that the sensor switch its ok because he is very expensive, considering the little thing that is it , the fan is allready controled thanks you have a good afternoon
hello ,thank you for your answer, i think i have misspoke , sorry , does it activate when you have the bike at idling speed ? can activated after 200 meters, driving fast ? I'm trying to find out after how long the water is hot enough for the fan to activate because I don’t want to take the radiator out of the motorbike( I have disassembled far too many times this trial , but if i have not choice...) to try the switch sensor putting it in hot water , and I can’t drive a lot because I’m in town right now have a nice day
Hey , I love you ... more seriously, I searched this but I had not found, thank you! Hello , thank you "you need to use high octane fuel" already used its sp98 ,I think is enough? as I say i think it’s the piston or ring "air leaks between carb and cylinder" already checked,nothing at all "the spring in the top of the carb maybe needs replaced" I didn't know it could do ,when the spring is worn , I'm going to buy another one, but looks good to me she go makes this just when she is cold thank you another question the fan is supposed to turn On , at idling speed ? or after how long is it supposed to going On thanks again to both of you, have a nice day
hello what it is the original setting of your 315r?phbl -because mine was with 13 turns for the air screw -for the needle its the 2st step from the bottom I changed the settings -air-screw :3 -needle:3 step from the bottom but she still does things strange to me: -if I put the starter,she go really high in the rpm(I almost thought the cable was blocked ,so much hight rpm) -It doesn’t all go down right away when I drop the throttle -she Knocking crankshaft its ok , but maybe the 3 ring its bad , not sure while riding, it runs just fine. but i think the idle speed its not pretty to listen but she holds the idle speed no air intake has the pipe, valve box its ok , crankshaft I don’t know she run gasoline 98 (i'm french),spark plug br7es , spark plug brown any idea suggestion , I would be happy , thank you have a good evening
@caravan_monster hey , yep is that , if you sell it, I'm really interested
@caravan_monster hey ! thanks for the answer , yep its the damper rod who is broken at home , surely in the same way ? because I found pieces in the fork that was not supposed to be in the photo, I'm looking for the rod which is attached to the cap who has a blue wheel which is not there either , the bottom is fine but the cap part is totally destroyed and of course all this piece is in one part normally , me it’s in 3 pieces (maybe a lego fork lol) this is the piece I'm looking for, but with the cap
hello, yes thanks until 2006 I think it's the same ,but impossible to find one on the net , I had found one in my country (france) but too expensive 600 at this price(close) I have a fork almost complete
Hey , thanks but all its for paioli , sadly
Hi all I'm looking for a damper fork (right side) but I do not really find anything (maybe one in russian site but...) used or new its a montesa 2001 , rainbow showa 39mm you have an idea of a site? where can I have a chance to find one or maybe an adaptable damper forks ? its the n11 have a nice day !
hey , if it is only the piston and not the crankshaft bearings, I am reassured me who can’t find the segments in france it's perfect. Thank you , both
Hi everyone, I tried to look but found nothing? maybe i have looked badly , its my first montesa and she makes a hard sound , like that it smells like a bearing crankshaft ? i haven't dissasemble the cylinder because i wait the parts (seals) so its was normal sound or not ? thanks for all and have a nice day (sorry for my english)
Hello I am French , living in France , I apologize first of all , for my grammar , passionate motorbike car and paragliding I have a 315r with small worries but I like it anyway for the car it is a sunny and paragliding a alpha 3 This is all ,if there are any questions a nide day !
