Simonelongus
37 -
Thank you, I will try to build the cable. I have many mappings that were given to me by the Italian importer. As soon as I build the cable , I will update you. Right now it's almost unrideable because at low revs it doesn't go it's very smooth, but as soon as it goes up the revs it goes off abruptly. Thank you.
Okay so I take it that this is not normal. I have to build the wire, now I'll get into it. Thanks
Found the problem and solved it at great expense!!! Eventually when the bike started to heat up the main bearings seized up. I gave and then gave again to figure it out until they really seized and I figured out where the problem was. The engine now has new bearings!!! Question: is it a 280cc is it normal that at low revs it runs poorly and as soon as it gets up a little bit of revs it suddenly shoots out power? I can't drive it much.... Is it a mapping problem or are they all like that? Thanks
Thank you for your immediate response. The problem was the injection cable not making good contact!!! I hope that was all it was. I give you my best compliments for your efforts and the book you made!!!
Simonelongus started following From hot it mumbles and goes out
Hello everyone It's been a while since I've posted and in fact I've relapsed!!! I bought back an Ossa , I was in love with it!! and from late 2012 so a 2013 even though it has the ECU marked still with 11 final. I'm writing because I have a problem, when the bike is nice and warm it shuts off on me, like it's running out of gas, it revs up as I ask and then drops goes up and then drops all the time. I don't know what to look at. Unfortunately I had sold everything kscan harnesses etc.... I can't tell if it stops getting spark or stops getting gasoline for a few moments. Thanks Translated with DeepL.com (free version)
hello, I have some if you leave me the email I will send them to you
Have you tried to insert the R2 mapping wet? I am finding myself very well.
Hi, you triggered the spring ... You have to load it up, you have to give it a ride and fit it where it is now.
- 1 reply
- 1
Anyone have wet mapping or very soft mapping to use the Vertigo? I tried the Gas Gases and they are much easier. I tried to do it with the software but it creates too much vacuum in the first part of the throttle, and then I think that one made by the house is designed to make the engine run better.
I want to buy the wificom module, can you tell me the factory code. I don't want to buy it from an official dealer. Can anyone help me? I don't know if the code is: GK-WFCOM2-0003 or GK-WFCOM2-0001 If anyone can help me Thanks
Manual sent, who is still missing?
I was wondering in the 2018 model there is no switch to change the mappings like on the other models. Is it possible to put a switch also in 2018? As was done for the Bones, it was enough to switch 2 pins
Thank you all for the manual, arrived. Thanks..
Hello, interested in the 2016 manual I'll leave the email if anyone can send it to me bernardi.simone@live.it Thanks
