wardo78
22 -
Thanks Steve, I'll look into those two. Ward
Hello All, I am working on freshening up my 2020 Evo 300 4t for the coming season and I have two questions at this point. 1- I bought a TRP shock to and am wondering if it matters which way I orient it? It looks like shaft up gives easier access to adjusters, but print on the shock indicates shaft down. I searched the web and people seem to do both. 2- My bike tends to dribble gas out of the carb vent lines when I am riding rough terrain. I don't relish getting gas in the streams, etc. The float level is to spec, and it still happens. I remember running vent lines up and over the carb in the past, and I am wondering if this would help, although I imagine it might defeat the venting. Another thought I had was to run the line into a capture tank where it could just evaporate from. Thoughts on both of these? Thanks, Ward
I did a search and came up empty handed. I noted that the 2t and 4t Evo's have different part numbers for the shift levers. Are there any aftermarket shift levers available? The OEM one had a fight with a rock.... Wardo
Oset 12 set-up and getting the little guy going....
wardo78 replied to wardo78's topic in OSET Electric Trials Bikes
We gave him his Oset 12.5 eco last Wednesday, and he took to it immediately. I left the pegs on and down and he never thought twice about using them. They live on 4 acres, so he just started riding around the house, he also made tight turns around trees in their orchard. What I was most impressed with was his ability to come to a halt and remain balanced. He can ride REALLY slow without needing to wiggle the bars... until he can't and then he tips over. Being 4, he is prone to losing attention. 2 things that I did to help with that was 1- Play, "catch Poppi" in which I jogged ahead of him around trees and such and he followed. He was happy to do this until I was tuckered out, 2- Have me follow him on my trials bike. He wasn't as enthused to follow me here, so I just putted around behind him. Overall, it was a total success, thanks! Ward -
Thanks for the additional info! ward -
Thanks for the responses. I am very much looking forward to getting the little guy on a trials bike. It is just a week away! Ward -
I am giving my 3.5 year old grandson an OSET 12r and I an wondering what tire pressure folks are using and any other set up tips (not that he'll notice at first!). Also, since he is skilled on hs balance bicycle, my plan was to pull the pegs off for the first ride and let him get used to it, then put the pegs on a day later or so. Thoughts on this or any other suggestions on making his transition easier? Thanks, Ward
Great question, I love my 4t, and thanks to you the clutch is amazing, but... I'd REALLY like an electric bike. Preferrably at the same price point as your average gasser.
Hebo's are hard to come by in the US nowadays. Last night while searching around, I found some discounted Stylmartins in leather that look a lot like my old Hebo's. They are 50% less than Gaerne's and Sidi's, so I think I will order them. I did find a few positive reviews, one in particular from someone I know and trust. Thanks for the responses! Ward
My 16 year old Hebo boots are pretty much toast. I traditionally wore Sidis for MX and Enduro, so thought I might try the Zero 2. Actual user reviews are non-existent. Can anyone weigh in? How do they compare to other boots you've owned? I normally wear 43's, but my Hebo's are 42's. I prefer a tight fit for trials... how is the Sidi sizing? Any issues? Thanks, Ward
I love my 2020MY 300 4T. I shimed the clutch and replaced the plates with Barnetts, thanks to Don Williams, and put a 9t on the front which was a bit much, maybe adding 2 in the rear would have been better. I also put pegs that are18mm further rearward, which improved the balance for me. For hot starting, my fool proof method is to simply hold the throttle wide open while kicking. It starts first or second kick consistently. Wardo
This thread has been dormant for awhile. I am wondering if anyone has updates on the various e-trials R&D efforts? Is anything full sized with a clutch other than the EM realistically coming to market anytime soon? Wardo
I want to give a HUGE shout out to Dan! He has patiently helped me sort out my clutch issues on my 2020 300 4t, and even provided the parts gratis. My bike had what I understand to be the classic Beta clutch drag, with rpm's dropping significantly when in gear and the clutch lever being disengaged. It was causing me to stall at inopportune times, and to need to blip the throttle while doing tight turns or between steps. First, Dan sent me some super clean 3mm Barnett clutch plates he had around. They helped some and cleaned up the engagement a bit, but there was still drag, so next up he sent me a bunch of the requisite washers. I installed two of the .0025's, and it made a huge difference! I was SO much more confident on the bike and was immediately riding things I hadn't been able to since back in the day. I hadn't realized how much I was blipping the throttle to compensate for the clutch drag and resultant RPM drop. I am going to experiment with adding one of the thinner ones and see what that does, but am happy with my first WAG. They were a total game changer, and I have Dan to thank for it! Thanks Dan and everyone else here who shares your expertise so freely! Ward
Thanks Dan! We've met a few times at NETA events back in the day. PM me how much do you want for the Barnett plates, I'd love to try them. Ward
28 pages is a lot to wade through.... I bought a new 300 4t from Mike Comer and love the bike, but find it stalling at inopportune times. I used to be a decent trials rider, but have been on hiatus for 10 years, and am now 60. With that in mind, my technique is a bit rusty, but I do remember how to ride.... So, my thoughts on the stalling is that the clutch is dragging, and the resistance stalls the engine in situations where I have zapped on to a rock, need to stop then turn tight. Somewhere in all of the clutch shenanigans that happen in this simple maneuver, it will stall at times, cold or warm. Is the original clutch mod Dan illustrates applicable to my bike, or is there another approach? Thanks, Ward
