AlexR
13 -
Are we still up for the cable? Just let me know what I owe you and I can send an e transfer.
Thanks,
Yes, I have gotten it in, so just need to build it and get you a price.
I’ve been pretty busy with bike work and other stuff, but should be pretty soon.
My email is:
markh@olympus.net
best way to contact me, since I just now saw this!
Excellent! Thanks you so much.
Take care,
Alex
Yes, I’ve just been super busy with bikes and grandkids...
I’ll try to start working on one tomorrow.
Hello, I noticed you responded to a post regarding a smoky Osssa. In this post, you mentioned that a diagram was a later year with a race type LH bearing and that the oil feed holes on those models were blocked off. I have a 2015 280 that started smoking intermittently after I repaired the gear box. I assumed it was the LH seals but your post makes think otherwise...do you know if the LH seals would cause smokiness (intermittent) in a 2015 280?
Thanks,
Alex
- Show previous comments 3 more
Thanks Peter! I am in Canada. Another member was kind enough to give me software and was initially going to make me a cable but he has not followed up and it sounded like a lot of work for him. Do you know where I can get a cable?
The intermittent is strange...I thought maybe it just takes time to build up in the crankcase???
Hi Alex, would you be ok to email me, I find the message service quickly fills up on TC and I have to delete a few things to allow more entries. Pls try me on peterboettchernz@yahoo.co.nz
If you were in NZ I would offer to reset your software and there is a straight forward tune to lean or richen the mixture over the rev range.
Due to the backward facing cylinder, there is a step at the base of the crankcase mouth where 2T oil builds up with use. When starting from cold, this oily residue mixes with the combustion fuel/air until it is all burned off, then after use again, the build up returns. Is this what you are seeing? Very rich from cold for a long time? Bye, Peter.
Just remembered, there is another Ossa rider in Canada who has a cable set, will see if I can think of who it is. What city are you close to?
