seadogtypeBadger
11 -
Hi Again , what type of oil and quanity, ive got automatic trasmision oil , at 200cc ??
Hi Will try a ride , Thanks
Hi After much messing about with the above have it all thrown together before total strip down , want a quick ride , clutch not realeasing, been playing with it what seems like ages , have had the clutch cover off and operate clutch the plates appear free , fitted larger plunger but none of this has worked, . Operate the clutch arm fully still wont release. The clutch basket is partially behind the flywheel weight , guess this needs to come off to remove clutch basket,do i need pullers for this ,begining to get out of my comfort zone or should I have a good ride around with clutch pulled in, ( probem is finding a field ) Sorry about the waffle but its getting near to being left in shed and find something else , been told its not worth putting into garage , cost against value. Cheers
Hi guys again Montesa cota 349 Gearbox and clutch oils, Found out the quantities etc but can anyone tell me is there a trick how to check the levels without draining and refilling, put the required amount in and no sign in the filler hole/ no dipstick is it just guess work to top up or a complete change ????
Hi thanks for that ,a rebuild , thats what was in my mind, was told on purchase engine had been rebuilt , ha ha, may try to get going first, could be interesting but thats what we buy these toys for . Cheers
One last question guys, for now , as the engine has chips in the black coating over the engine is there an engine paint / spray presumeably heat resistant out there I can touch it up/repaint or will it require stripping and redoing by a professional??? Cheers
Thanks a lot again , looks like I'd better make a shopping list Cheers
Hi again Two more pic, help , pretty sure there should be some kind of mounting plate between the two holes on the top of the frame and top of engine??? Also any idea of the year . Thanks guys
Thanks that helps
Hi Thanks , tank just rested on for photo
Hi Have just bought a montesa cota 348/349 ?? can anyone out there help identify what ive got before I go looking for parts, chassis and engine numbers match 51M24661, the frame appears to split and has a sump guard at the bottom and has been painted white (badly) should this be black not seen a white one??. Hopefully I have managed to load a couple of pics. All replys gratefully recieved. Cheers Seadogtypebadger
