New Clutch Baskets
Hi all I have managed to get some brand new clutch baskets From original manufacturer. I only have a few if anyone needs one Basket only £40 which is what they cost me
st 125 2004 stator
Thanks for the reply . Ill email them
st 125 2004 stator
Hi all . My sons bike has all of a sudden backfired a few time then stopped . now we have no spark . searched on here and found some test data which i have done to find no readings between ground (white wire and the green wire I have readings between white and red but nothing between white and green or red and green . So I suspect the stator has failed . Can these still be repaired or can anyone point me in the direction of a replacement . Neil
- St125 carb
St125 carb
Thankyou for the info That is a great help. Neil
St125 carb
Hi . Would anyone be able to point me in the direction of the carb setup float height and specs for a 04 st125 please .
Sy250 electrical power
Thanks for rrply . I have the Longridge version But wanted to add another just for this event.
Hi all . I would like to add a temporary additional front light . It already has a lighting kit but wanted to explore the possibility of a long distance night trial So my question is does anyone e know the power output capacity of a standard lighting circuit on the sy yamaha engine Regards Neil
St clutch availability
Hi yes . I was wondering if Me.bers would be interested in them if I could and if so what prices they would be willing to pay .
Hi Is there any call for the clutch baskets on the older st range I know the bikes are getting older and the baskets seem to getting hard to get hold of
Clutch
Hi again . I have ordered a second hand basket . Which is said to be from same bike however . Just wo during if any sherco experts can id if it is as looks a little different and alot lighter one I took off is the solid one and the new one doesn't have what looks like a weight ?
- Clutch
- Clutch
Txt dellorto phbg 21
Hi does anyone know of the correct jets and slide pin for the txt 70 cc Regards Neil
- TXT 70cc
stogga
