loydee
22 -
Many thanks to all of you for the solutions - a mighty relief I can tell you. Me first Villiers project will now not be confined to dark corner of shed. Cheers!
Hi, am working on a 30C engine (similar to 8E) . Just put new mains in the crankcases,and drew the 2 crankcases together using longer bolts. Now the r/h crank web (Ignition side) is touching the inside of the crankcase.There were no thrust washers on the crank when I stripped it,and online diagrams show none present. What determines the 'end float' / centralisation of the crank anyway? Once I tighten the primary drive sprocket fully will that pull the crank away from the opposite case, a quick tighten has already moved it a little.... Thanks in advance, for any help to ease my frustration with this
Good to see another Dalesman returning to action. If it's any help to you I've got a lot of Dalesman photos/brochures up on my Flickr page here: across pages 2-5 ,and a bit about my own Dalesman project here: scroll down page a little. Good luck with your restoration!
Mystery solved -thanks to some info from the chap at Villiers Services -it's off a Norman, they used Blumfield hubs on a few of their machines e.g TS,and the B1S Norman B1S
Hi there, have acquired a 19" rear wheel which appears to be from a lightweight British bike. Brake plate is marked TF Blumfield. I know they did some front hubs/brakes for Velocette Venoms but this is not off a small Velo.. Can't get any more info on 'net. Any ideas if it's something rare before I start hacking about and swapping to alloy rim etc.Pics here Thanks in advance,much appreciated. http://www.loydee.blogspot.com/
Hi, have just acquired what I assume is a 150 Villiers engine with 55mm bore. The gearbox,primary & flywheel mag seem fine. Unfortunately it's seized, so rather than rebuild this probably underpowered unit, I was wondering if a 197 bottom/top end would fit into the existing gearbox,primary,mag set-up? Thanks in advance... Twinshock Blog
For a diagram go to http://www.alpha-sports.com/suzuki_parts.htm select 1981 then TS185 then clutch. Great bikes -I ride em in Twinshock Enduros and Hillclimb -( www.loydee.blogspot.com for TS185 ramblings!) Good luck.
Thanks for your help re: tap. I ain't looked at it for a while but think the tank has a hexagon shaped recess and the nut on the tap just pushes into it on mine,i.e it's not held captive by the plastic. Inside the tank there is NO nut at all (mind you it'd be hard to fit it on the tap's thread anyway given the lack of room...). Seems like either bits missing or the tank/tap junction is buggered. May see about having a threaded collar inserted (or a cheap 2nd hand tank! )
Hi am also in the process of rebuilding my Fantic 200. Came in a bad way from Newark jumble with a worn big end, a moped back wheel, bent swingarm and bright purple & silver. However it ran and was
Hi after years of waiting came to try out me Fantic 200 (Back-kick model) and seems like clutch is stuck. Maybe due to standing I know but I also had some of the pushrod parts fall out a coupla years ago when I fitted an extended arm (for lightness). Just in case I fitted in wrong what is correct order please. As engine is lying on clutch side what order do you insert components down the tunnel? Thanks :-)
Yeah had similar thing on 198 Bultaco -ran fine then let me down at start of 1st event. Went to replace points/stator assembly and took seal out to behold a main bearing minus some of it's outer cage :-(
VintageCota - thanks very much, information passed on.
Have been asked for ignition timing for Cota 348 and can't find said info on the net, anyone know? Thanks!
Seeing as there's very little internet material on Dalesman I've posted some literature on http://groups.msn.com/TwinshockInfo/shoebox.msnw. I hope this is of some use.
I posted on here re my Dalesman project back in August 13th -still in old posts -and received a lot of helpful information . I have some copied brochures and stuff (ta Simon 'Cleanorbust') email me on loyd.lisa.sims@@virgin.net (remove an @) if you want anything scanned
