HMAD
12 -
Don’t know if any can help but I have a 2017 TRS RR that runs bad when hot. I ride for around a hour then the bike feels different with a loss of power and sounds slightly different like a spluttering sound. I have cleaned the carb changed the o rings in the cylinder head as my coolant was think and a grey colour new spark plug
My 2017 TRS RR kickstart has started to jam. I have to rock the bike in gear to solve the issue anyone know what it could be before it gets worse ? t
Hi, can anyone recommend or know of a garage in. Bolton / Manchester area ? Think I need my crack seal doing on my 2010 sherco 125. Thanks
Well I have removed the tissue and slight bit is still leaking putting that down to build up. The bike has got a lot louder with slight popping noise. Also my clutch seems to be really grabby but after that little ride it seems to have got a lot better
Hi, this might seem like a really daft question but I'm a complete beginner, I have excessive amounts of black fluid dripping from under my exhaust. I have removed it today to have a good look and when I look through the silencer I seems I have some tissue in there. Is this normal ? Thanks
I've noticed today on the clutch cover there is a small dint / scratch and possiblity lost its shape. I've ordered a new cover and rings for it. As for the black fluid will this disappear once the bike is ran for a while and opened up. Thanks
Again thanks for advice
Thanks for you replies, I've had the bike around 2 month and haven't really had it out properly just round my garden due to lock down. To be honest everything I seem to tutch goes wrong. Changing coolant ( drain bolt was cross threaded) changing gear box oil ,( leaks every time the bike warms up slightly) ect lol. Back to the black fluid, I've just has a look at the bike around the exhaust and all seals/joints seem to be ok ( no black fluid) . There seems to be a couple of pipes in the area would they have anything to do with it ?
I think it's crap from the exhaust it's a 2010 sherco 125 . It's seems to be leaking near the rear suspension part of the exhaust. Could it be something to do with the bike being on the side may be flooded ?
Hi, I'm having trouble with oil leaking from the clutch cover case ( attempted 3 times now) with new o rings every time. Maybe I need a new cover as it appears there is silicone in the grove were the ring sits. I have removed this and it's still leaking. When I think I've sorted it and start the bike to warm up it then starts leaking black fluid from under the rear exhaust some were. Can anyone tell me what the problem is thanks
Hi, new to the forum. I have bought my first bike today (2010 sherco 125), aswel as riding it I'm hoping to learn about general maintenance can anyone point me in the right direction for manuals/books to pick up from Thanks
