OK, for anyone still reading this string, I will tell you how to do a lightweight TL250 that kicks _ss in competition and is a blast to ride and weighs 203lb dry with no titanium. 1st off, a stock TL250 does not weigh 218 dry, more like 225. It also has only 10 inches of ground clearance and still has a high center of gravity. BUT..It has an awesome motor, and that it why it is worth doing a custom. I have a custom TMI chrome Molly frame kit which came with a swingarm, chain gaurd, aluminum airbox and UNI filter, double layer plastic molded skid pan, exhaust, Supertrapp silencer, all for about $325 in 1980 or so. The first step on any TL250 is to get rid of the seat and exhaust. Make a seat out of sheet aluminum, even a hack like me can do it. Get some foam from a foam shop and get it covered by a upholstery shop, all easy and cheap and you save over 2 lbs, high up weight, immediately. Then take the exhaust off and sell the big boomerang on Ebay. Get some tubing from a stainless supplier, like Bassani, in a 180 bend, whatever radius you ask for, and some straight stock, and get a local welder to piece it together for you, should be less than $100 for the whole thing. Get any silencer of your choice, I have the Supertrapp with the resonator to make it quieter and use the pressure rings to tune your Throttle respnse to your liking. The SuperTrapp is not 1 pound, much heavier. I picked up an aluminum silencer off Ebay UK and will be doing a stainless short pipe with this silencer later this year. Get some Falcon shocks as they actually work, unlike the originals, and weigh about 1.5 lbs less than other steel shocks. If you have money burning a hole get the alloy ones for about $485 and take off another pound or so. Get some 6.5" Rental bars if you are over 6' , the stock steel bars weigh a ton. If you are using the stock frame then I would do the cut tube under the engine trick to increase clearance. I would take the swingarm to your best friend welder and see if he would make a chrome molly or aluminum one for you. This could cost $300 and it is lower weiight but will help your cause. If you live near a guy with a Fraser or TMI frame you could try to duplicate it at some frame fabricator but it would be costly. I almost bought a Fraser off Ebay UK last year for about $700 including freight and customs but the finished bikes look too much like stock TL250's for me. The TMI is almost exactly like a Sammy Miller Highboy, which it no doubt was based on. Since Honda refused to sell a serious trials bike in the USA, TMI did it for them. I have won many trophies on this bike and those who have ridden it say it is the best vintage bike they have ridden and that Sammy himself would be impressed.
I do not have time to figure out how to add pictures of the bke to this site but I have many in digital format and would be happy to send to anyone that wishes to provide their e mail address for me. I also have a custom TLR200 (183.5 pounds dry ) and beautifull, some say the best they have seen, and an absolutley mint RTL250S with less than 2 hours riding on it. MY TMI TL250 sat in storage for 23 years so it is in great condition. I am lucky to have 3 of the best bikes of their type on Earth. Oh, I also have a TL125, in average conditon and unmodified, but I might get the urge! Pictures to those who wish.
Regards,
Nine
PS - Don't give up on the TL250 projects, too much fun to be had!
