fox889
45 -
That’s a real shame, but at least they replied to you & you know where you stand. I’ve read that it’s a right ball ache to get it registered without any paperwork or acknowledgment from DVLA so good luck anyway.
Sitting on a trials bike is uncomfortable……sitting on a Montesa trials bike on a public highway might be very uncomfortable bordering on madness! Be a while yet for this 349 as the engine hasn’t been touched yet, but has been promised end of this month!
The initial response was pretty quick, maybe around 3 weeks which is perfectly acceptable. However, the actual dvlc form I filled in is now on week 5 or 6, doesn't really matter as the bike isn't finished anyway. Let us know what they say, be very interesting.
Guys, my 242 has the later 304 forks on, just changed the seals etc, drained out 450ml of fork oil = 225ml per leg.....is this too much? Always thought these bikes took around the 200ml mark per leg & just wondered whether you think 225ml per leg is too much oil? Appreciate any views/thoughts.
Hi Barnsey, I wrote the following letter to DVLA along with form V888 [downloaded from DVLA's website]. I received the answer from a Jacqueline Davies 'Vehicle Casework Unit'. I'm thinking that if your bike was registered with the DVLA it's on their database & all they need to do is access that using frame & engine number, confirm it with you, then you fill in a V62 + £25 & Bob's your Aunt's second cousin, sorted! All it took was a few minutes & a second class stamp, well worth trying at least. Let us know how you get on please. Re: V888 I bought this 1981 Montesa with a view to restore back to it’s original condition. There are signs that lights & lighting wires from the magneto are present, indicating that this bike may have been registered as a ‘road bike. Would you mind checking your database to see if this bike has been registered? Frame No. 51M ***** Engine No. 51M ***** Kind regards Nicholas.
There's some very good points there, thank you for that.
Well, I'm still awaiting the engine back from the guy who said he'll strip & rebuild it........he's been so busy he hasn't managed to do it yet, which in fairness, ain't no real problem. Ok, so twiddling my thumbs, I noticed the bike has "lighting wires" coming from the magneto so "assumed" this could have been for a road registered bike? I had no paperwork for her, no plates, no nothing to say she had ever been on the road. I read loads on here & other forums & it seems nye impossible to register a bike with DVLA without some sort of paperwork. I wrote a really nice letter, very informative, photo's of the frame & engine numbers etc etc expecting DVLA to write back [if at all!] & say "can't be done"....end of. Blow me down, received a letter from Vehicle Casework Unit c/o DVLA saying "Thank you for your recent enquiry" etc etc please find your registration number as *** ***X. If I want register her, send £25 + V62 & it's all done. Even checked the reg on the 'car history' on DVLA's website & it shows me she was indeed an October 1981 349cc Montesa, last taxed 30th September 1986, last V5c [log book] change 7th July 1983. I find that fascinating myself. Big question is........does this make the bike more desirable?........more appealing?..........more valuable? I shall register her but whether I put her on the road I don't know. I cant imagine it can be much fun flat out at 40mph on an old trials bike...can you? Any thoughts? Appreciate you reading this waffle!
Dr Nosh: I’ve put the 22mm bars on & everything seems to tighten down fine, the risers/saddles (call them what you may) seem old/original. They have 1-5 on the lower saddle, not exactly sure why? The shims you were talking about, I assume, go top & bottom of the bar itself? In this case, a) are they needed and b) would they fit? Appreciate your thoughts. Tayld: made the point that I’d got original tapered rear sprocket bolts on a non countersunk sprocket. I had noticed that but it didn’t sink in as a possible problem. I’ve put an M8 bolt & spring washer just to show what it’ll look like ( I need some new spring washers from the “ironmongers”😜), I think when all the bolts are changed to M8 it’ll be fine. Front mudguard on, front wheel tightened up, new pinch bolt installed & she’s looking ok I think. W.I.P. Work In Progress as they say!😁 If you think I’m doing summat wrong, then please just shout, no umbrage will be taken I assure you! Thanks for looking.
Thanks Dr Nosh The old bars were Micron 22mm so I assumed that 7/8” (22mm) were standard fitment. The new bars seem to sit ok so again, I assume one of the previous owners had changed the bars & fixings.. The front & rear wheels are only a finger tight fit just to see how things line up. The rear sprocket had ( and still has) tapered bolts on the rear sprocket so couldn’t use any washers (I assume that’s correct?) thread lock is a good idea & when everything lines up I’ll probably remove the rear wheel & loctite the bolts on the sprocket as suggested, good idea! Well spotted the missing pinch bolt.....mitigating circumstances M’lud......I draw my learned friend to the previous paragraph stating “front & rear wheels are only finger tight”😁😁 I had been down to the local ironmongers (do people still call these ironmongers?) & bought a load of s/s nuts, bolts & washers, one of which was specifically for the front fork pinch bolt but hadn’t fitted before the photo was taken. Phew, got out of that one!😳 Appreciate your interest in the refurb.
They’re standard 22mm bars so, in theory, they should be ok. Slightly wider by a tad by the looks of it.
Again, I use the word slowly to emphasise the rate this refurb is taking. Local engineering guy turned me out a couple of spacers for the front & rear wheel, how anyone previous can lose a spacer, heavens knows. Doesn’t really matter as a tenner for both spacers is money well spent. Both front & rear wheels now line up pin straight. The rear shocks were quite short according to one of the comments on here, so a pair of Betor ‘steels’ were acquired from Bike revival uk, ace guy Simon listened patiently to my thoughts then came up with a pair of these, £105 all in inc delivery, again, money well spent. The old ones were 310mm & these are 360mm, makes the a*** end look really nice! The old Micron handle bars weren’t in that bad a condition, but I felt if these were put back on it wouldn’t do the rest of the bike justice. Inmotion had a pair of ‘proper’ trials bars for £50 odd I think, there’s no ‘bridge’ between the bars which again, makes the bike look ok. They’re next to go on. I was going to purchase a ‘long’ rear mudguard, the one I have at present is a ‘short’ one, it’s cleaned up ok so rather than fork out £60 (inc p&p) I thought I’d just leave it be for the time being. There is a financial limit to what I can spend on this. My 242 has a short one, previous owner made a plastic ‘bridge that gap’ to stop all kinds of crap flying towards the engine, I shall have to fabricate something similar in Perspex or plastic, I’ll see what the bank balance says first! No sign of the engine, dare say it hasn’t even been started, it’s no hassle really, as this was always going to be a summer project in readiness for a winter trial or something next year. Now I’m on the home straight as it were, it would be nice to have the engine rebuild at least started. Once it’s stripped, I’ll have the casings to paint satin black. If anyone spots something I’m doing daft or wrong (perfectly feasible knowing me!) then just shout! Best wishes Nick
Just a wild guess......inmotion?
In motion have a budget pair for about a hundred pounds, which isn’t that bad, this is never going to be a competitive trials machine, nor is the rider 😜, just want it looking it’s best & be able to keep up with the others!
I thought they looked like an '80's Jap shock Honda-Suzuki etc etc. When funds allow, I'll look around for some new shocks, engine is still away & an unknown quantity money wise! Thanks for your input.
