nick1
35 -
yes it is in place and it is clean. And the gasket under number 61 is. And what copper should it be? The previous person wrote
is there anyone who can understand? They gave me an answer, but perhaps google translator did not translate it specifically
here you mean?
There is no one on the forum who understands the carburetor?🥺
Help me set up the carburetor dellorto phbl 26 bs 1994. Motorcycle Gas Gas 1994, 237cc engine. The old carburetor parameters that were originally when I bought the motorcycle. 35 Pilot Jet 108 Main Jet D36 Needle 50 Slide 60 Choke Jet 350 Float Needle valve At these settings the carburetor is probably leaking. He just doesn't eat. Then I bought a 200 valve from Float Needle and bought a Main Jet in all sizes. I started trying to change the settings, I just changed the Float Needle valve to 200 and Main Jet 122, but it didn’t do anything. It still pours. Could it be a problem with the floats? Their weight is 2.8 grams. Maybe the float chamber I have is 19 mm at the wrong level. What settings are needed for my 237cc engine. Maybe the float chamber level is wrong? Maybe you need more or less?
Thanks everyone for your help! I bought 5w30 mineral oil and machined the rings so that the springs would press the clutch harder, but it didn’t help. The problem is probably in the carburetor!
Where I live you can order with an expected delivery time of 4 months! The disks were installed correctly, I couldn't confuse anything.
I’ve already done this, but not for the bolt, but instead the part of the clutch itself where the spring is in the aluminum part, I ground it by 2.5 mm, but it didn’t give anything. I’ll buy oil and I’ll exhaust it. Do you know what the length of the spring should be?
Thank you, I can’t find such oil (There are only synthetics or semi-synthetics. Or maybe the discs are still slipping due to the fact that the package is smaller?
How oil do you put in the box of your 1994 Gas Gas JTR? I tried MOTUL TRANSOIL EXPERT 10W-40 and Putoline RS 75 this is a synthetic oil. I haven’t seen a video that before, or 5w-30 was regular oil, or was it mineral oil? Where can I find this? Could the Sentetic oil cause disc slipping? What oil do you use?
photo of clutch discs
The clutch will probably slip. At high speeds there is vibration and the motorcycle does not move! The size of the package is 25.8 mm, I checked the feredo in place and did not lag behind the disk. Spring size 37 mm.
In what space do you mean? Can you take a photo so I understand? Do you mean maybe the feredo itself, there are grooves there, are you asking about them? I am writing to you via Google Translate
