dannyb
38 -
Thanks for the help and the info. I found i had one of the cheap tachs already in my toolbox so hooked it up to see what it read. It appeared to be a little high so turned the idle down a quarter turn. One thing i noted is the readout (digital) fluctuates a little as the bike idles - is this normal? Mine as currently set, reads 1800 but will flick to 1680 maybe once every 1 or 2 seconds??
Hi, just picked myself up a repsol 260 - what a bike! ? Can anyone recommend a reliable and easy to use tachometer for setting the idle speed please ? Is something like this suitable? https://www.ebay.co.uk/itm/UNI-T-LCD-Digital-Tachometer-Speedometer-Tach-Meter-Measuring-Rang-0-99999-P8T8/312860215918?hash=item48d7ec0a6e:g:s4kAAOSww5Zd20vg I'm led to believe this needs to be checked regularly as the atmospheric conditions can affect and alter the idle speed... any truth in this? Does the operating temperature of the engine also affect the idle (I.e. hotter engine = higher idle speed) or does the efi self calibrate this? Thanks in advance
I'd recommend Endurotyres.com ! http://www.endurotyres.com/ Quick and a good price and do postage
Another question in the same vein - does that mean you could in theory take a factory 300, and put a 200 bareel/piston/head and adjust the jetting to make a factory 200?
I've got a few small dents on my headpipe ('14 evo 300 2t) now, what's best/easiest way to get them out ? Short of buying a new obviously! Can you bung the ends and blow them out like a motocross pipe with heat? Or do the fill with water and let freezing action pop them out like you would a 4stroke header?
Only 28 entries this weekend is that right!?! (myself one of them) for a national that can't be right surely
I stuck one of my vents back on with a hot glue gun last night. Worked ok. Bit messy, but was my first attempt
Curious why it's so much more than a leonelli/jitsie/apico equivalent? Does it come with correct connections already on? I'm guessing the other offerings you have to cut into the existing kill switch wires?
Went to these venues years ago but can't remember what access is like - can we camp with camper van at the two venues ? Kelly farm on the Friday night Brousentor farm Saturday night ?
Rode it, loved it, be back next year
I agree, makes sense to me, but then that was the rules I learnt under. Sections still needed to 'flow' but you could put in some more technical aspescts without it being unrideable for anything less than a five!
What oil does everyone use ? Different weights for the different legs?
Anyone know if you can buy a complete suspension bearing kit (after market ideally) for a late model evo? Or do you have to order all the individual parts?
We get three trials bikes in a lwb t5 with second row of seats in fine, adding additional tie points helps. Can do two enduro with all seats in, but easier if you take one or two seats out
So after an afternoon of tweaking and testing I ended up with the following 50 pilot, jjg needle on third (middle), 128 main and air screw just past 1 1/4 out. I tried same jets but with a standard needle (jjh) which felt smooth but just a touch too lean still. I'm awaiting some larger pilots/mains and when I get these I might experiment with standard or leaner needles on 3rd or 4th clip. 128 and 50 were largest I had in my box
