Triad
    39
  1. Sorry to resurrect a 6 years old topic but... was it the model with or without the "powerjet"? I just fitted one of the chinese PWK clones on my 250 Pioneer engine with Explorer exhaust... the stock jetting seems to be too lean (38 idle jet, 120 main). I just replaced the idle with a 45 as the bike tends to die even with the air mixture screw totally closed. Not sure the 120 main is big enough, we'll see.
  2. Don't know how to "repair" the gear lever. I could drill a hole thru and use a passing bolt, maybe, covered with a piece of hose for the time being? Or I could use two metal clamps to keep an L shaped piece attached on it?
  3. Thanks... makes perfectly sense. I don't think I'll be on the hunt for a Pioneer exhaust, it would probably make more power up top but I plan to use it for "semi-trial" stuff at low speed, so it's probably better to keep the Explorer exhaust with the smaller carb. I guess the cylinders are also different on the inside (bigger intake/exhaust ports)? I never worked on Amal carbs, so don't have any jet for it... hopefully the stock setting will work with the actual setup.
  4. Ok guys, managed to find a Motoplat coil and the right kickstarter lever for this engine. Also got a tank with petcock, but they're both pretty much trash. I poured some pretty rich premix inside the spark plug hole and the engine came to life, with huuuuge surprise. Started but died after 1 second. The second time I started it, lasted maybe 2 seconds. In the meantime I tried to put the tank in place with a hose going to the carb, but ended up badly with my cursing and fuel everywhere. Today it started at first kick (!) and for maybe 8 seconds... I managed to twist the throttle a couple of times before the fuel into the bowl finished and it died... but it's aliiiive! As you can see the carb is the Amal from the Explorer engine... should I get something more modern and better for the Pioneer engine? I read it had a 32mm. The guy I got coil, kickstarter lever and tank from, kindly sent me for free a rear brake cable and a broken gear lever (I'll have to find a way to make it work).
  5. This is the engine fitted, the exhaust and carb in place. I found a guy who's got a MAR 350 partially broken in parts in his garage but doesn't seem happy to sell the kickstart lever etc. without the whole engine block. 🤨 I still need the kickstart lever and the 2pins Motoplat coilpack to try to start it... from there I'd at least know for sure the engine works and could start looking for a better clutch cable, rear brake cable, silencer etc.
  6. I guess no "modern" bike has a similar lever? The fact it's on the left side makes things harder anyway.
  7. Hei guys, got some good news for a change... Checked and the intake diameter is 36mm like on the other engine, so I was able to fit the carb manifold to the cylinder. Also found out the cylinder will take the Explorer exhaust, the flange is removable and in its place I fitted the Explorer header. So thankfully won't have to look for different exhaust/carb. Have found a guy breaking a MAR 350, so I should be able to get an original Motoplat coilpack... but can't say if the kickstarter lever will fit.
  8. Thanks, if the "stator" is broken I think I'll simply abort the project and will try to cut my losses... found a guy here in Italy who's breaking an Ossa MAR 350 but don't know the production year... was the MAR still around when they changed the teeth of the levers on the engine block?
  9. Today I was away so couldn't check the gear lever and the exhaust compatibility... will try to do it in the weekend. Hopefully I'll find a solution for both
  10. Uh, forgot to ask: the bigger shaft on the kickstart lever is on the enduro models only or it was also on other models and depends from the production year? I mean, the Gripper/Yellow etc. have this same bigger lever shaft?
  11. Uhm... I think I'll invest the money for the coil, as I'd need it anyway. But the rest is definitely more expensive and harder to find. I'll check the exhaust later today and will report back... thanks a lot for the advice, I've been toying with this project for a year now and taking a short ride in my yard would already mean a lot to me LOL
  12. The carb was fitted on a rubber manifold, no bolts... but yeah, it's smaller. Didn't check the exact diameter but I'd say it's something like a 24-26mm maybe? The biggest problem is that I'm missing the kickstarter lever and the coil... I could at least know if/how the engine runs if I had them. Is there anything that will fit when it comes to kickstart lever? Maybe from a newer bike from another brand? It's clear I'll have to gamble and buy a Motoplat coil without knowing if the engine runs, but for those old lever sellers tend to ask pretty unreasonable money and they're not easy to find. Even a borrowed one would be ok, I'd gladly pour more money into the project if I knew for sure the engine runs OK.
  13. I didn't pay enough attention before buying the new engine, the owner didn't know much about it but... even the gear pedal is different? About the exhaust, I see they have a similar flange... maybe the Explorer one will fit? If I have to buy all these parts with the risk of the engine non even being completely fine I'm screwed big time.
  14. Uh, so the coil integrates parts of the CDI? Damn, in this case won't work. Can I test the rotor/stator without a working coil? Today I finally managed to literally kick the engine in place, only to find out my kickstarter lever won't work... different shaft. 😭
  15. Uh, forgot to ask a very important question: with the Explorer I received a Motoplat coil but it's the single pin version. I also bought on amazon a 2 pins "universal" coil... will the engine work with it or it absolutely requires the red 2pins Motoplat unit to work?
