andyh
    12
  1. Hi all anyone know the amount of gearbox oil and weight for a TXT 250 GAS GAS 2000model. doesnt seem to be mentioned in the excellent ;-) manual. thanks in advance for the replies andyh
  2. many thanks for the replies. just been out today (Warden Law, Seaham) and it performed great. very responsive and torquey. different to the TY250 Mono ive just sold. downloaded the strange parts guide (pictures instead of CAD drawings) and the 'how to understand the chassis number. i ran the bike with 100ml oil per 5l of petrol. seems ok. again cheers and happy trialing. andyh
  3. Hi all just bought a TXT 250 Andorra 2000 model and need some form of handbook / manual to get me going. anyone got one / sell / download etc. any thoughts on this bike? performance, issues, problems etc the swing arm has a cast number on it with 2002 at the end? what this all about? whats the difference between an andorra and others models? any advice will be helpful. last trials bike i had was TY250 mono 1984ish. many thanks in advance andyh
  4. Hi all i need a new rear mudguard (front if possible as well) for my 1984 TY250 mono. i know you can buy new
  5. Hi all thanks for the responce. the kick start lever is in the correct vertical position. i moved it one tooth forward last night however it then touched the cylinder head. when i kicked it over the part that attaches to the shaft did not touch the case? and appears to have the internal stop working. the kick start assembly is correctly attached with no play on the splines. this is confusing. i will try to fabricate some kind of stop. where i attach this too is anyones business. anymore thoughts appreciated. andyh
  6. Hi all i have a TY250 1984 bike. the kick start lever hits the clutch case when starting the bike. this has left an indent in the case which iam sure will split. surely there should be a stop somewhere? i cannot see where it should go or where i could fit one. any suggestions thanks andyh
  7. can anyone give me the air screw setting for the above bike. it is running very rich (sooty plug) and does not start very wel.. i also does not want to rev out (not good when half way up hill) any help appreciated. andyh
  8. Hi all i have an early Ty250 mono 84-86 i think and dont really know what model it is. it does have an N in the engine number. no remote shock and plastic tank. any help cheers andyh
  9. thanks for the reply. my forks have a 3in spacer on top of the spring then top fork nut. would this mean it still goes where you said it does. many thanks in advance. andyh
  10. hi all i have just replaced the fork seals and have a prob. the fork has a long spring (20in) and a short spring (25mm / 1.5in) in length and i cannot remember where the short spring goes. does the damper rod go through the spring before if is secured by the allen screw going through bottom of fork slider? i seem to remember it falling out of the chrome fork leg when i turned it upside down to drain the remain oil. many thanks in advance andyh
  11. Many thanks. eventually used a wooden broom handle tapered which slotted in and locked the rod. dropped the front end complete and removed each oil seal with wheel, mudguard and forks still together. worked fine. i'll try 280ml. many thanks andyh
  12. Hi all i am in the process of dismatling my TY250 mono forks jap inport to change fork seals. the screw holding the damper inside the slider is just turning as is the damper rod inside. it looks like a special tool is needed to stop it spinning. anyone got a suggestion as to what i could use. i do not have a manual. download anywhere? is 300ml of oil ok for an average rider? thanks in advance. andyh
