rock hopper
    97
  • Website URL
  • ICQ
4,506 profile views
  1. Can I use synthetic Type ATF F oil on a 2003 200 txt. Read some ware not to use synthetic on these.
  2. I have a 2005 4rt and was wondering if anyone has the bearing # for the head set bearings? or are they the same bearing used on newer 4RT ?
  3. Have seen on some ty175 they have replaced factory starter arm with a al one! Does anyone know what they used ?
  4. Saw that you can replace stock triple clamp (loose stile balls) bearing with new contain ball roller bearing . Was wondering if anyone has new stile roller bearing number. Thanks
  5. Is yhere any info on what size shock that was used and how far they where moved ?
  6. I have notice that the rear shock top mount have been moved down . Does anybody have info on this mod ? Thanks
  7. rock hopper
    Ty 80 1974
    Was wondering how much oil and what wt oil should I use in the TY 80. Also does anyone know where to get factory manual also ?
  8. Was wondering does anyone know how much oil per fork and what weight ?
  9. I have a tlr 250 and was wondering what front and rear sprockets riders are using on them. I have 9 tooth on front and 41 in rear now
  10. rock hopper
    Tlr 250 1984
    Was wondering if anyone knows how far above triple clamp should forks be? Thanks
  11. anyone know what stock wheel base was??? and where you can down a manual for bike Thanks
  12. Try this stuff cleaned to ty tanks with it and they are like brand new inside Rock Hopper http://www.rusteco.com/
  13. Have a Dunlap on my TLR and it works great
  14. Think I found out that it is a 16mm 1.5 RH thread bolt ???
  15. Was wondering if anyone know what the tread size is for puller or where you can buy one Thanks
