wilsyfm403
    6
1,257 profile views
  1. wilsyfm403
    Fantic 300
    hello i've got a 300 pro and it really could do with a new carb i've heard stories of reed valve conversions and mikuni carbs any help would be gratefully recieved cheers Matt
  2. Thanks for the help, ive got the cank out and its having new con rod, bearings and new mains. I managed to get a barrel and piston on an exchange from Bill pye and hopefully be back together soon thanks again.
  3. wilsyfm403
    300 Engine
    Hello, ideas and help needed, where can i get my 300 barrel rechromed and new piston, or does any one have any bits that might be of some use as mine decided to sieze on saturday. Do any other engines fit or are the other 301 302 303ect engine parts compatable? Happy new year and all.
  4. Have you seen the mods for fantic clutches on Trials central? I have modded my 300 and a friends 200 with it and it works a treat look at the actuator arm on the back of the engine this needs to be extended about 20mm then fabricate a new cable mount from steel/ally, that bolts onto the old mount but takes the clutch cable across 20mm and down about 10 mm. I made mine from ally and incorperated a cable adjuster into it. The engine needs to come out to do it really. There are pics of the mod by others on here some where!! Good luck where about are you in the land of the long white cloud?
  5. I'd like to put my 300 on the road, but i've never had any papers for it does any one know where i can find out if has been previosly registered. I'm going to ring the dvla tomorrow but any other ideas would be welcome.
  6. Recently purchased a fantic 200 professional 156cc, it has been played with by Mike Hann? and i'm having trouble getting bits for it. the clutch i bought for a 200 was too small and all the pics of a 200 i've found show the chain drive to be on the left where mine is on the right. Any info would be greatly recieved.
